My G3PO-M gyro
My G3PO-M gyro
I built my G3PO with some modifications. The rotor turns in counter-clockwise direction similar to my other DC gyros. The blade mount is simplified by installing strap on bottom only and shims under the blades. This way, I have exact amount of down angle on both blades plus less work. The blades are Aerobalsa covered with Ultracote and it was not coated with acrylic. It does have the tip weights. I used pushrod for rudder control. The motor is Custom CDR-Double with custom made mount and the battery is Poly-Quest 3 cell 850. With the modifications, it seems to fly just fine.
Wahid
Wahid
