NEW! Yokomo Land Jumper now in Stock!
Yokomo 1/14 Scale All Terrain 4WD Buggy
Now available!
Whether you want to run on concrete or on the dirt, Yokomo Land Jumper can handle whatever you throw at it.
Include oil shock, double wishbone suspension system as well as dirt proof 4wd shaft drive. Further more, Duralumin Full Flat Main Chassis is supported by Upper Deck and Tube Flame. This will ensure to protect the machine from your Extreme Action!
This high quality machine also comes with Servo, ESC & Motor!!!
What a great value for the money!!!
3 Colors to choose from:
Yokomo LJ-01BK Land Jumper (Black)
Yokomo LJ-01SL Land Jumper (Silver)
Yokomo LJ-01CL Land Jumper (Clear Body)
Features:
Duralumin F&R Damper Stay
F&R Double Wishbone Suspension
Large Capacity Oil Shock
Dirt Proof Full Covered 4WD System
F&R Gear Diff
Aluminium Motor Mount
Aluminium Center Shaft
Adjustable Slipper Clutch
Full Ball Bearing
Hard Type Sus Mount
Turnbuckle Upper Arm & Tie Rod
Include: 280 Size Motor, Steering Servo, ESC
SPEC:
Length: 300mm
Width: 200mm
Height: 110mm
Wheelbase: 205mm
LJ-RS242 Yokomo 2.4GII Land Jumper Running Set also available.
Now available!
Features:
F&R Gear Diff
Full Ball Bearing
Hard Type Sus Mount
SPEC:
Length: 300mm
Width: 200mm
Height: 110mm
Wheelbase: 205mm
