Yokomo DP-DIBRS DIB Ver.RS [PRE-ORDER]
New line up for Yokomo DIB!
Yokomo DIB ver. RS
Using resin materials, high spec yet reasonably priced!
Off course you can use DIB parts to pimp it up as you require.
Features:
Belt Drive 4WD System
Front One Way
Rear Spool Joint
Drift Steering System
Adjustable Oil Damper
Drift Spring
Aluminium Motor Mount
Turnbuckle Rod & Upper Arm
F&R Universal Shaft
Full Ball Bearing
__________________
www.banzaihobby.com
Online Hobby Shop direct from Japan!
Join us on Facebook!
Yokomo DIB ver. RS
Features:
Front One Way
Rear Spool Joint
Drift Spring
F&R Universal Shaft
Full Ball Bearing
__________________
www.banzaihobby.com
