Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
NEW Kyosho Kits and Parts
Old 06-26-2013, 07:53 PM
banzaihobby
Default NEW Kyosho Kits and Parts
New Kits an upgrade parts from Kyosho now at Banzai Hobby!!!
PureTen kit GP V-ONE R4s Rubber Tire Spec (Engineless Kit)
R4 incorporates the latest in racing technology and rubber tires as standard!
High-tech racing weapon supports your quest for world domination!
With a rear exiting exhaust and rubber tires the new V-ONE R4s adds a new dimension to the world-class racing performance of the V-ONE R4. Inaugural 1/10 GP World Champion Adrien Bertin and Japan’s Takaaki Shimo combined their formidable talents to design the R4 as an easy to drive high-performance machine able to compete at any type of race. While maintaining the ultra-low center of gravity design and reduced mass moment through the entire drive train, this machine has the setting flexibility to deliver improved performance for all drivers from high-speed circuits to more technical courses. Race-proven KC Slick (M4) rubber tires included with the high strength and rigidity of the 15-spoke wheels deliver exceptional grip performance for superior control on a wide variety of road surfaces. Born and bred for high performance, this machine will take you to the forefront of the racing.
PureTen GP V-ONE SR Petronas Tom's SC430
Kyosho GP debut race to the Cup car freaks a lot of goals and of course, the height of the potential to step up to meet the top category, such as All Japan Championship is a major advantage in the future. Lighter weight and thorough, the configuration of the parts of the EMPRESS World Champion V-ONE RRR machine has the ability to respond to wear and ease of running a wide range of settings with a low center of gravity. By new on the outside Long 2mm over the (ratio RRR) of the rear suspension pivot ball, raise the capacity of the rear grip, has raised more straightforward driving characteristics. In addition, the properties are also supported (optional) to retrofit foam tires, the ability to showcase a variety of excellent in the race. That slide into each part exchange to options in accordance with the improvement of the technique, its speed is to fast and advanced classes. It is also possible to convert to the final specification RRR. Awakening to the joy of racing, racing machine entry "V-ONE SR" The ultimate aim for the Ru on it further, please Experience the thrill of motor sports.
For the Mini-Z Fans
These are Limited Numbers so get in quick to avoid Disappointment
About Fine Hand Polish
A new surface finishing technology that provides a hard glossy finish in bright lustrous colors. The hardened surface protects the paintwork from marks and dirt so the beautiful car body is easily maintained in all its original glory.
Ferrari 458 Italia GT2 White ASC
Real car impact! Collector quality and realism.
Equisite workmanship of the Auto Scale Collection produces showroom-quality display models. They can also be matched to a suitable MINI-Z chassis to recreate the excitement of scale racing. Also compatible with the advanced performance and enhanced scale realism of the MR-03 chassis!
LOTUS EXIGE Cup 260 Red ASC
An for the Plazma Formula Fans out there!!!
Front Suspension Conversion Set ROUTE246
ROUTE246 adds a sharper competitive edge to the Plazma Formula with the development of a modified front suspension compatible with small diameter front tires. The 3-point set creates a 4mm higher road clearance with 3mm longer king pins and aluminum bulkheads that can take hard shocks. Multiple collars on the king pin are included for precision chassis height and upper arm angle setting. Titanium coating on the king pins realizes ultra-smooth movement. 1mm extra setting angle for the king pin (compared to normal) allows 4-stage bulkhead settings.
Please come Join us on Facebook for Weekly Specials and Updates
Banzai Hobby Team
