Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
NEW Tamiya Kits !!!
Reply
Old 09-28-2013, 02:20 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default NEW Tamiya Kits !!!
New Tamiya Kits now at Banzai Hobby !!!
TB04 Pro Chassis Kit
The TB-04 PRO chassis is the successor to the TB-03 chassis, and this race circuit chassis inherits its efficient shaft-driven 4WD system with a newly developed, horizontally-positioned motor placement design. The chassis features a number of newly-designed parts and provides a blend of speed and handling that R/C racers are sure to enjoy. The TB-04 shares the same double wishbone, independent suspension parts seen on the TB-03, TA-05 Version II and TRF 416/417 series of proven chassis designs.
DB01RR Chassis Kit
The popular DB01 off-road 4WD chassis receives an update made with racing enthusiasts in mind. This limited edition chassis kit includes a number of Option Parts to give the chassis excellent performance in competition racing. The chassis lower deck is compatible with square-shaped batteries, and the kit includes big bore aeration dampers for high-level off road driving. The front and rear of the model receive fluid filled and sealed gear differential units, reducing the need for maintenance and allowing longer running times.
DF03 MS Chassis Kit
The mid-range shaft-driven 4WD buggy DF-03 chassis was developed from racing data, and the DF-03 MS kit takes its capabilities one step further by fitting a range of option parts. Use of a slipper clutch, assembly universal shaft and center one-way set boost drivetrain efficiency and provide sharp handling, while 4-wheel double wishbone suspension enables a range of settings.
This limited edition buggy features a chassis that is loaded with performance enhancing parts and a Dark Impact body shell with special markings designed by TRF driver Satoshi Maezumi.
The following Hop-Up-Options are included:
53791 DF-02 Assembly Universal Shaft
53924 DF-03 Heat Sink Bar Set
53925 DF-03 Slipper Clutch Set
53926 DF-03 Aluminum Damper Set
53931 DF-03 Center One-Way Set
53940 DF-03 Hard Turnbuckle Shaft Set
53941 DF-03 Aluminum Turnbuckle Steering Rod
53948 DF-03 Aluminum One-Piece Propeller Cup Joint
53949 DF-03 Lightweight Battery Stopper Pin
53984 Buggy Racing Wing
51000 Hi-Torque Servo Saver (Black)
Porsche 911 Carrera RSR - TT02
The Porsche 911 Carrera RSR joins the Tamiya TT-02 chassis touring car entry level line-up. It is a legendary Group 4 car which had a body weighing just 900kg with a 300hp-plus horizontally opposed 6-cylinder engine, and still holds a place in automotive enthusiast's hearts today thanks to its exploits with racing teams the world over. In 1973, the year of its release, it won the European GT Championship, plus the renowned 24 Hours of Daytona and 12 Hours of Sebring races. The works prototype in predominantly silver livery with the Martini stripe also took the checkered flag in the famed Targa Florio race.
Tamiya has faithfully reproduced this sleek racing machine in 1/10 scale on the TT-02 entry level touring car chassis. The TT-02 chassis platform is the successor to the TT-01 as it incorporates many new features to make it even easier for the new R/C kit builder to assemble and learn from. The TT-02 chassis performs well as cornering and overall speed has been enhanced to take advantage of new electronics available on the market. In addition to the TT-02 being an ideal platform to start from, R/C hobbyists can expand its potential by adding many of the Ho-Up-Options available to increase the cars speed and performance.
Ford Zakspeed Turbo Capri - TT02 Gr.5 Wurth
The Ford Zakspeed Turbo Capri Gr.5 Würth joins the ever growing selection of iconic sports and race cars offered on the easy to assemble TT-02 chassis. The car was the result of the tie-up between the legendary Zakspeed racing team and Ford. It achieved excellent results throughout its racing career, the highlight being in the 1981 season in which it blew away its rivals.
Also we have a wide selection of Tamiya TB04 parts in stock and the list is growing!!!
Tamiya TB04 Spares and Hop Ups
Also check us out on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
banzaihobby is offline
Old 10-10-2013, 05:59 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
GAZOO Racing TRD 86 - XV-01
Participated in the TRD Rally Challenge final race of 2012 , is the electric RC car assembly kit of GAZOO Racing TRD86 which attracted the attention Toyota Motor president and driving . The model to realize a lot of polycarbonate a low form which was finished in a compact . Reproduction without leaving low hood , front fenders rise to smooth , such as the shape of the rear diffuser , the characteristics of the 86 Toyota . In addition to the sticker headlights sharp eyes , tightens the facial expression light case made ​​of polycarbonate also part of . In addition , I have prepared a sticker sponsors and more marks , the graphics of the Red & Black . Chassis adopts the XV-01 of the belt drive 4WD corresponding to traveling on dirt road , of course . 6 -spoke wheels of fearless gun metal color , I put on racing radial tire . I can enjoy plenty of runs on a wide range of situations .
Body Set GoPro Monster - Sport Super Swift
Body Set Porsche 911 - Carrera RSR
Body Set Ford Zakspeed - Turbo Capri Gr.5 Wurth
Please join us on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
Old 11-12-2013, 01:55 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tamiya new RTR Zakspeed Capri WRT - TT02 now at Banzai Hobby!!!
This is a fully factory assembled and ready-to-run R/C model of the Ford Zakspeed Turbo Capri Gr.5 Wurth. The painted and finished super detailed polycarbonate body is mated to the easy to maintain TT-02 4WD on-road chassis platform. The TT-02 chassis features a 4WD drive drive-train with fully independent double wishbone suspension. The pre-installed 2-channel radio gear system operates on 2.4Ghz technology which allows you to run your vehicle anywhere without the need to worry about other R/C enthusiasts nearby.
The TT-02 is the new standard in Tamiya’s entry level cars. The chassis has the battery pack and motor placed longitudinally on the left and right sides of the chassis respectively. The skid-shaped lower deck enables a greater roll movement range during cornering, and the 4-wheel double wishbone suspension is equipped with identical left/right suspension arms and uprights, making maintenance and assembly a simple task. The drivetrain features a motor mount which allows up to 10 different gear ratios as well as front and rear enclosed gearboxes equipped with resin 4-pinion differentials. In addition, 2-types of ground clearance and wheelbase length are possible by altering parts position, making it a flexible machine too.
Please check us out on Facebook for Weekly Specials and Updates!
Banzai Hobby Team
Old 11-14-2013, 01:35 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
XB RTR GAZOO Racing TRD 86 (TT-02)
Please Check us out on Facebook on Weekly Specials and Updates
Banzai Hobby Team
Old 03-27-2014, 01:43 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New Kits from Tamiya.
TA06-R Chassis Kit - TA06
It is the electric RC car chassis kit full of optional parts dual-drive 4WD chassis of the belt and gear , the TA06, I finished in specifications race ready to race , such as Tamiya and Tamiya Grand Prix . Change in carbon reinforced parts a lot of plastic parts such as the gear case and bulk head , upright and suspension arms , suspension mounts use a pure racer TRF418 for fight to the world stage . I have a dedicated parts rear stabilizer . In addition , suspension of outboard front and rear , mounted on a carbon damper stay dedicated high-performance short TRF damper . It was up to the rotation efficiency by incorporating an aluminum middle pulley mount the popular and are standard on TA06 MS in the drive system . In addition , running up a notch , you aim to win the race and equipped aluminum turn buckle and aluminum pillow ball , and fluorine coat suspension ball .
RTR Porsche 911 Carrera RSR - TT01E "White Version
This is a fully factory assembled and ready-to-run R/C model of the Porsche 911 Carrera RSR "White Version" car. The painted and finished super detailed polycarbonate body is mated to the easy to maintain TT-01 Type E 4WD on-road chassis platform. The TT01 Type E chassis features a 4WD drive drive-train with fully independent double wishbone suspension. The pre-installed 2-channel radio gear system operates on 2.4GHz technology which allows you to run your vehicle anywhere without the need to worry about other R/C enthusiasts nearby.
Please join us on Facebook for Weekly Updates and Specials
Banzai Hobby Team
Old 08-22-2014, 01:59 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Neo Scorcher - TT02B Bright Pink Metallic
The Neo Scorcher on the TT-02B chassis is now in Bright Pink Metallic! The TT-02B uses the TT-02 as s base, adding longer suspension arms, CVA shock units, and buggy bumpers to give it great off-road performance. Of course, it retains the TT-02's excellent drivability and easy of assembly and maintenance, while motor cooling ducts and receiver case add to the model's durability. It also includes a large wing to go with the newly-designed tough body, plus stickers based on the original Terra Scorcher's livery design.
RTR XB The Hornet Black Metallic
This is Limited Edition release of the Hornet, which comes with a black metallic body. This model marks 30 years since the release of the venerable original.
Now comes at a XB RTR
Banzai Hobby Team
Old 08-29-2014, 02:42 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More New Kits from Tamiya
1/10 TG10-Mk.2 FZ Chassis Kit
Description:
This kit sees the TG10-Mk.2 glow-engine R/C chassis fitted with a brand new engine!
The FS-12FZ Engine
The Tamiya FS-12FZ engine has a capacity of 2.1cc and features tapered sliding carburetor, plus an efficient heat sink for heat dissipation. It offers an excellent combination of linear torque and high output, while being easy to setup and maintain. It features a 2-speed transmission.
XB ENEOS SUSTINA RC F TT-01 Type-E
Among the new machine that Lexus is thrown in SUPER GT in 2014 to "GT500 class" and "RC F", I reproduced the machine of team Le Mans, which was the main sponsor high-performance engine oil service station "ENEOS" to deploy "SUSTINA" is a complete electric radio control car. Starting with spindle grille characteristic, which is becoming the new face of Lexus, and reproduced realistically polycarbonate slit of fender top reminiscent of a DTM machine, such as the modeling of the body side bottom, a form which is full of a sense of volume. Color ring and used as the basis of a vivid orange, decor graphics white, gold, and silver is also as it is the actual vehicle. Chassis shaft drive 4WD maneuvering characteristics controller Bull, TT-0IE. RC mecha adopted 2.4GHz worry of interference is less. By mounting the ESC that can speed smooth adjustment both forward and backward, you can enjoy feel free to have a nimble ride.
Please Join us on Facebook for more Weekly Specials and Updates!!!
Banzai Hobby Team
Contact Us Archive Advertising Cookie Policy
