Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
NEW Active Hobby Products
Reply
Old 05-30-2014, 03:04 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default NEW Active Hobby Products
New From Active Hobby the new Magnet Body Mount Marker and Off-Road Vehicle Wheel Lock Nut now at Banzai Hobby!
Product Features
6mm and post to be used in 1/10 scale car, I corresponds to the post of 5mm drift package system.
※ drift package, etc. use the spacer black accessories.
Was attached to the body posts, and cover the body. Was placed on a magnet attached After you determine the position, please marked with felt pens.
Product Features
Reproduced the hub of the actual vehicle 4x4, is a wheel nut realistic scale.
Because it is embedded a special 4mm nylon nut inside, you can use any type of vehicle in the wheel nut like normal.
(W / 4mm wrench into 9mm / 4 co-height diameter 11mmx)
CC01 CR01 GF01 Tamiya, etc., It is the design which is the best match to crawler-based and cross-country chassis.
Please Check us out on Facebook for Weekly Specials and Updates!!!
Banzai Hobby Team
banzaihobby is offline
Old 06-28-2014, 10:15 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New Active Hobby Products now at Banzai Hobby!!!
A AWESOME Way to dress up some much need bling to your Yokomo Drift Package or other drift kits with the new Products from Active hobby
Pillow Ball Mount Shock End for Drift Package
Pillow Ball Turnbuckle Tie Rod S (34 - 48mm 2pcs)
Pillow Ball Turnbuckle Tie Rod L (34-68mm 2pcs)
High Angle Rod End C Foot for Drift Package 2pcs
Get in Quick as these are Limited runs and will Sell FAST!!!!!
Please join us on Facebook for Weekly Specials and Updates
Banzai Hobby Team
Old 06-29-2014, 08:23 PM
collector1231
Moderator
collector1231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Beautiful products, guys! May get a couple off-road wheel lock nuts.
collector1231 is offline
Old 08-18-2014, 11:52 AM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The New Line up for Active Hobby is now at Banzai Hobby!!!
High Angle Steering Rod Set
In shape to avoid the interference of the wheel, is the steering rod of stainless steel balls inserted already capable of handling even narrow scrub
TRF Length Adjustable Pillow Ball Cap
It is a shock cap set that can adjust the vehicle height without changing the pretension. (Adjustment range genuine + 1mm ~ + 3.5mm)
. In stainless pillow ball inserted already, I will achieve the mount with no backlash.
Banzai Hobby Team
Old 09-18-2014, 06:41 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking at something new to Dress your Drifter/Racer up with then look no more with the new Active Hobby Accessories
Wide Flange 4mm Wheel Lock Nuts
5 Hole Wheel Nuts Silver
5 Hole Wheel Nuts Black
5 Hole Wheel Nut Socket (7mm)
Wheel nut socket designed for the 5 Hole Wheel Nuts
TRF Damper Pillow Ball Mount Shock End (2pcs)
Banzai Hobby Team
Old 10-03-2014, 02:28 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Active Hobby Aluminum Upper A-Arm Type C (2pcs) now at Banzai Hobby!!!
Comes in 5 Colors to match your Drifter
Blue
Dark Blue
Black
Red
Silver
Adjustable to 37.5 ~ 52mm Upper arm length
Largely improves the strength at the weak point of the single A arm
also im improves an removing slop an play in the caster
Please join us at Facebook for Weekly Specials and Updates!
Banzai Hobby Team
Old 10-20-2014, 04:56 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wanting to Dress up your WR02 Wild Willy 2 well look no more the new items from Active Hobby for your Wild Willy are Here!!!
WR02 Aluminum 7 Slot Grille Wild Willy 2
Also for the Drifters out there!!!
Yokomo Drift Package & Tamiya TRF Damper Tapered Piston 3/4-Hole
Please Join us at Facebook for Weekly Specials and Updates!
Banzai Hobby Team
Old 10-31-2014, 11:34 AM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Pillow Ball Shock Caps Length Adjustment Type 2 is now at Banzai!!!
for Drift Package aluminum dampers
The aluminum shock cap capable of adjusting the vehicle height without changing the pre-tension.
Stainless steel pillow ball inserted already
Old 11-17-2014, 12:13 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New Active Hobby Items now at Banzai Hobby !!!
Pillow Ball Steering Rod Set (20 ~ 25mm & 25 ~ 30mm)
Comes in 2 sizes
20 ~ 25mm
25 ~ 30mm
an comes in 4 colors
Black
Blue
Silver
Red
WR-02 / GF-01 Adjustable Upper Arm Rear (20 ~ 25mm & 25 ~ 30mm)
Comes in 2 sizes
20 ~ 25mm
25 ~ 30mm
Black
Blue
Silver
Red
Get in Quick as these are selling FAST!!!
Please Join us at Facebook for weekly Specials and Updates
Banzai Hobby Team
Old 11-21-2014, 05:57 PM
collector1231
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Neat stuff! I might order a CC01 later.... Can't wait!
Old 12-02-2014, 09:10 PM
zackS30
zackS30's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow these parts look amazing and looks like a lot of thought went into them! I'd like to get some new wheel nuts. I like the 5lug ones but I like those bright pink nuts too.
zackS30 is offline
Old 12-15-2014, 10:46 AM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Aluminum Wire Clamp
Helps protect your wires from touching the drive belt or shaft
It supports 12-14 gauge wire
Comes in 5 different Colors
Blue
Dark Blue
Black
Red
Silver
Get in quick will stocks last!
Please Join us on Facebook for weekly specials and updates!
Banzai Hobby Team
Old 12-22-2014, 03:56 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New from Active Hobby
Aluminum Motor Guards for WR-02 Chassis
Protect the motor of the WR-02 chassis well and support a tough, wild run.
Aluminum Steering Wiper for GF-01 Chassis
Support to steering work of the big tire 4WD. It is a steering wiper of CNC aluminum & strong.
With Ball bearing specifications and smooth also,little clearance.
Please check us out on Facebook for weekly specials and updates
Banzai Hobby Team
Old 01-16-2015, 02:01 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New From Active Hobby!!!
Piggyback Shock Cap for TRF Shock 2pcs
Aluminum shock cap with a dummy subtank matching both on road DRIFT/ off-road. It is most suitable for a dress-up.
With position of FF/FR/RF/RR indicator where you used all around for time of maintenance.
Aluminum Rear Tube Bumper for Tamiya Willy Bodies
Suitable for Tamiya Willy bodies.
Rear bumper146mm length made from 8mm in diameter aluminum pipe.
Active Hobby Matek USB Power Adapter 2.5A
USB power adapter appeared smartphone and tablet devices can be charged with a Lipo battery, etc.!
Supports DC power of 7 ~ 26V. In 2-6 cell Lipo battery and 12V car battery or the like for R / C, charge and various USB devices of smartphones and tablet devices is I can use. Leisure in the outdoors of course, also takes an active part in an emergency such as a power outage or disaster.
iPad in high-power specification of maximum 2.5A series is also possible charge.
Considering the heat dissipation, and adopted a design that takes advantage of the printed circuit board of the precursor.
Starting with lipoic cut off to prevent over-discharge, in four of protection function to prevent overvoltage Short reverse connection, input side (battery / power) also output side (smart phone, etc.) will also firmly protection.
5-mode liquid crystal display screen of, I will display the following status.
Voltage (V) - input (battery / power supply) side of the voltage-current (A) - output capacity to output (smartphone, etc.) side (mAh) - Did you power how much to the output (smartphone, etc.) side Display Total capacity at milliamps (Total mAh) - one of the one of the display time with ma total was powered much on battery (0:00:00) - The total power of the time in one of the battery
Note * connector for battery connection is not included. Please prepare separately to suit you you will use battery.
Please Join us on Facebook for Weekly Specials and Updates
Banzai Hobby Team
Old 02-08-2015, 06:27 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Body Mount Tower Bar Front and Rear for WR-02 / GF-01 & Willie Body System Aluminum Side Step
Body Mount Tower Bar for Tamiya TT02 / 01 F & R
Front and Rear Body Mount Tower Bar for Drift Package
For Weekly Specials and Updates please check us out on Facebook
Banzai Hobby Team
Old 04-03-2015, 12:25 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
TT-02TYPE-S Aluminum Front Damper Stay
Comes in Blue, Black, Red & Silver
TT-02TYPE-S Aluminum Rear Damper Stay
Reversible Rear Arm Mount for Tamiya TT-02TYPE-S
TT-02 Front Reduction Gear Unit ver0.8 (13 & 42T)
For any Updates on Specials please check us out on our Facebook Page
Banzai Hobby Team
Old 05-18-2015, 11:56 AM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New From Active Hobby WR-02 Aluminum Servo Mount Red
Another way to add strength and bling to your mighty Tamiya WR-02
WR-02 Aluminum Servo Mount Silver
WR-02 Aluminum Servo Mount Black
WR-02 Aluminum Servo Mount Blue
Also check us out on Facebook for many Pictures taken from 2015 Shizuoka Hobby Show
Banzai Hobby Team
Old 06-18-2015, 03:47 PM
banzaihobby
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New From Active Hobby the Torque Converter Unit for Yokomo Drift Package
It is adjusted in front driving force with hardness of the diff oil ! Torque converter unit for gear diff of the Yokomo drift package!
Torque Converter Unit Dark Blue
Torque Converter Unit Black
Torque Converter Unit Red
Torque Converter Unit Silver
Check us out on Facebook for the Latest Specials and Updates!!!
Banzai Hobby Team
