NEW Yokomo DPM Upgrades
New from Yokomo the DPM Aluminum Front "A" Arm Conversion Set and Aluminum Upper "A" Arm Set now at Banzai Hobby.
Increases suspension movement and steering angle. The damper can be mounted closer to the chassis on the lower suspension arm. Caster can be set from 4°-16°.
luminum Upper "A" Arm Set Blue/Red
Can be used on all Yokomo chassis which use upper A-arm suspension system. It is an aluminium upgrade to the standard plastic part
Comes in Blue or Red to match your Chassis
Get in quick as these are on high demand !!!
Please join us on Facebook for weekly specials and upates
Banzai Hobby Team
Banzai Hobby Team
