Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > Banzai Hobby Support Forum
Reload this Page >
D-Like WeightShfit-MEISTER Re-R HYBRID (PRE-ORDER)
Banzai Hobby Support Forum Get all the information and help you need right here, directly from Banzai Hobby.
Old 08-01-2014, 11:06 AM
banzaihobby
Cool D-Like WeightShfit-MEISTER Re-R HYBRID (PRE-ORDER)
New from D-Like WeightShfit-MEISTER Re-R HYBRID is now open for PRE-ORDER now at Banzai Hobby!!!
This is PRE-ORDER.
If you place PRE-ORDER, we will try our best to secure the product for you and will ship as soon as we receive them in stock.
ETA: End of August 2014
Absolutely limited number of first production available. So PRE-ORDER is highly recommended if you would like to get hold of this bad boy!
Further more, we will include bonus drift goodies for you if you place PRE-ORDER
SPEC, ETA etc can be changed without any notice by Manufacturer.
D-Like Re-R HYBRID is designed for people who like to Drift (whether for real drifting or RC)!! Real drift action and control feeling!
D-Like RE-R design Front Midship Layout. Rear action is like FR Drift Car! Rear Traction can be controlled by acceleration and shat drive! Front end is belt driven for natural feeling! By changing pulleys you can easily change F&R Ratio.
Rigid Silver Chassis!
Hopped up with Aluminium! Bling Bling!
Aluminium Parts include, F&R Lower Arm, F&R Knuckle, F&R Damper Stay, Rear Solid Axle, Front One Way, F&R Bulkhead, Steering Unit, Servo Mount, Spur Gear Holder, Battery Mount, Front Upper Arm, Front Upper Sus Mount!!
Standard Ratio: 1:1.58
Battery position can be changed according to your set up.
Include Aluminium Oil Dampers specially designed for RE-R HYBRID!
By calculating Front, Rear, Left and Right Balance, Gravity, speically designed suspension and non-matching (F&R) Suspension Block will create "Real" control and action!!
Newly designed front knuckle & Upper Arm
Center Motor Layout.
Following items are not included
Radio Gears, ESC, Motor, Servo, Battery, Charger, Body, Wheels / Tires
Get in Quick as these are on High Demand, So Pre-Order now to Avoid Disappointment!
Please Check us out on Facebook for Weekly Specials and Updates!
Banzai Hobby Team
