Help with chargers
Help with chargers
Hi there
from the site i'm looking at there seems to be a couple in the price range, i was hoping to spend (about £30-40 )
and these are:
http://www.modelsport.co.uk/prolux-m...products/39979
http://www.modelsport.co.uk/etronix-...products/36541
Would both of these be ok to charge 2 - 3c LiPos, 5000mah or so?
and I can't tell, but i don't know much about chargers, would i need a power supply to run these?
thanks for your time
and these are:
RE: Help with chargers
ORIGINAL: guver
Either one will work for a 2s or 3s x 5000 mah and they both run on 12 v DC power. They are very similar to each other.
I just want to make sure i'm getting the right things, and to double check i'm getting stuff that will be safe with each other
My Feedback: (325)
It would depend on the specific job you are doing at the time , it has to be able to provide same or more power than the charging job you are doing.
At least one of the chargers has a max of 50 watts of power so in that case a ps with 60 watts would be adequate for any job. At 12 volts it is about 5 amps. The 50 watt charger is capable of doing 5 amps and for the 3s will use up the 50 watts nicely. (power is speed)
5 amps x 12 volts = 60 watt
For the 2s pack charging at 5 amps will only use up 42 watts max. A ps with 40-50 watts would probably be ok. I'd get a 60 + watt ps just in case.
the charger i got in the end was this one:
http://www.modelsport.co.uk/prolux-mini-lb-6-peak-detect-charger-/rc-car-products/39979
100w and 8a -
should be fine as far as i can see?
