lipo parallel question
CA
Hello fellow rc'ers! Can any of you folks tell me if themah of a lipo pack matters, when run in parallel? I wouldn't think so, but figured i'd better ask before i start hooknem up. Thanks much
CA
RE: lipo parallel question
You can parallel different mAh packs of the SAME cell count.
You add up all the mAh of the pack to get a total for the charge rate.
1000mAh + 2200mAh + 3300mAh = 6500mAh
1C rate is 6.5AMPS
1C rate is 6.5AMPS
