Help how to cycling a 8.4v 3000map batteries
Hi guys
i have two power cell traxxas 8.4v 3000map nimh and i wont to cycle them.
discharge at what amp?
discharge down to what voltage?
can i cycle them i series?
i have a turnigy accucell-6 charger.
thanks
CA
RE: Help how to cycling a 8.4v 3000map batteries
Your charger can't discharge fast enough to damage your battery.
That said try discharging at the max.
Discharge down to 1.0V
I would discharge in parallel.
Your charger doesn't have the output to charge them in series in a reasonable length of time.
i charge them in series they are 7 cell packs it dose 1-15.
the charger will put out a max of 5amp when charging.
so you would discharge them down to 1v
haha
right i get it
do you no how hot a brushless motor i a emaxx should get mines geting quite hot
thanks
think as a rule of thiumb (literally) you should be able to place a finger/thumb on motor for at least 4secs before you have to remove- personally I dont let my motors get anywhere near as hot.
Definitely too hot, you are reducing their life span. I think at worst they should be warm, subjective I know but near too hot to handle is way too hot in my mind
My Feedback: (325)
ORIGINAL: julian.paton
how hot should batteries get mine are all most to hot to touch
120 is a long life span , 150 is a shorter life span. 200+ causes damage with each cycle.
they are nimh bateries. they are all most to hot to touch after running.
when i first got it, the run time was 30mins now only about 15mins if that. i have runned the car about 23 + or -.
I would cycle and charge the packs separately. If you have a decent VOM, you could test each cell using push-pins in the alligator clips. Old-skool. [8D]
