Hobbico Field Charger MKII Failure
GA
Guys,
I have a Hobbico field charger mkii, and it has ceased to charge! In fact, it will not turn on. The fuse checks out ok, and I have removed the panel/board from the case and visually, no signs of anything being cooked. When plugged in to the 12v power supply (deep cycle marine battery), I have plugged in a 5-cell battery into one of the charge ports, and a voltage meter in the meter ports. The meter reads the battery voltage, but pressing the charge button has no effect.
The charger is out of warranty by a year, and has worked flawlessly until now. Sending it in for repairs is not cost-effective, so I'd like to repair it myself. My knowledge is limited, but if I had a schematic, I'd at least give it a try.
So, all that said, does anyone know what I might look for first, or have a schematic? Any help would be appreciated. Here is the mfr's. webpage for the charger:
http://www.hobbico.com/chargers/hcap0290.html
Thank you,
Rick
Thank you,
Rick
RE: Hobbico Field Charger MKII Failure
Sometimes, stuff just breaks. I use it as an upgrade opportunity.
If you lack the skills and equipment to troubleshoot it, you should give it to someone who can. My local mom-n-pop computer repair guys are great with all electronics.
My Feedback: (41)
Yours may have been newer but these are a very old design. Mine was sold years ago, used, for about $20, so look around for a used one if you really like the design. It was quite good if you are not using A123 aand Lipo(sort of OK for Lipo).
