If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 9 of 9
Thread: batteries
  1. #1
    Join Date
    Feb 2012
    westbrook, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    batteries
    hi..i bought a new batteryfor my plane..the old one was4.8 volts/600mAh the new one is 4.8 volts/2200 mAh. the new battery wont charge up.the light is on the charger so i think its charging but two days later and still no charge..what do you guys think is wrong?
  2. #2
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: batteries
    Hi, welcome to RCU. I'd guess it is a charger trouble.
    What are you using to verify charge?
    and airplanes were in
  3. #3
    Join Date
    Feb 2012
    westbrook, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: batteries
    im using a voltmeter for rc...it works because the radio batts register charged...could it be my charger wont charge the batt because its2200mAh,as opposed to 600 mAh? thanx
  4. #4
    Join Date
    Jul 2007
    Warner Robins, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: batteries
    The "new battery" might be bad.
    Some battery charges will not charge if the battery is drawing too much current.
    I assume that the battery charger will charge the old battery.
    Also, there were a few chargers that came from the NiCad days, were intended to charge both the transmitter and the receiver batteries, and did not work unless both were connected.
  5. #5
    Join Date
    May 2008
    Winnipeg, MB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: batteries
    ORIGINAL: frankieboy
    If it is charging the battery will be warm to the touch. Also check and see what the output mAh is for the charger, if it is only putting out 50 mAh then that is 44 hours or more since you lose some to inefficiency.
  6. #6
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: batteries
    I don't think that your charger can tell what capacity it is either.
  7. #7
    P-40 DRIVER's Avatar
    Join Date
    Apr 2005
    Cedar Park, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: batteries
    I assuming you changed out a 600 MA Nicad for a 2200 MA Nimh. You are using the charger that came with your radio, correct? the charger that came with your radio is probably putting out between 50-70 MA. Not a good choice for charging that battery. I am also assuming, the battery you bought, is 4.8 volt and not a 6 volt unit. It sounds to me, that you might be better off, going and getting a 600 MA Nicad, which can be bought for less then $20, and saving yourself a bunch of extra effort and money.
  8. #8
    Join Date
    Feb 2012
    westbrook, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: batteries
    thats what im going to do...thanx everybody
  9. #9
    Join Date
    Dec 2001
    FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: batteries
    The old 50 to 70 milliampere charger will charge the 2000mah battery just fine, it will just take a much longer time, about 48 hours for a 50 ma charge on a fully discharged 2000mah battery. As long as the charger current is greater than the self discharge current, a charger will fully charge the battery if you give it enough time.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
