Charging 2 lipos simultaneous with ICE/EQUINOX?
MN
So I have a DuraTrax Ice charger and a Electrify Equinox balancer I have been using to balance and charge my aircraft lipos. I rencently got a electric car and am using 2S 5000Mah LiPos in it. I have 2 packs. I have been charging the packs one at a time with a 2s balancing adapter on the equinox and the charger set at 7.4v 5A charge. (The equinox says it can only "interface" at 3A but I've never had a problem and honestly never knew?) What I am wanting to do is wire a harness and charge both packs simultaneously.
In my mind I reason that the charge lead would have the 2 battery positives hooked together to the balancer red leads(why are there 2?) , then 2 small black bananas and 2 large black bananas each hooked to a cell ground(these packs have a 4mm red, a 4mm black, and a small bananna black in the middle...I assume 1 positive and a main neg plus the small neg as the 2nd cells balance ground?) I am figuring then I would set the charger to 14.8v(4S) and 5A charge and the balancer would just see it as 1 4S 5000Mah pack? Will this work? Safety concerns?
Is there a better way to charge my 2 packs with the equipment I have? I am mainly just thinking I would be able to get them both charged in the same time as one, and I wouldnt have to set the charger and swap packs to get ready to run my car. Is it really necessary or beneficial to be charging through the equinox each time? does anyone have a "pinout" diagram of the plug leaving the equinox? Thanks in advance. Todd
RE: Charging 2 lipos simultaneous with ICE/EQUINOX?
What C rating for charging are your lipos? 5ampa is charging at 1C. Unless your lipos are rated higher then charging two will not be quicker because your chargers output cannot be increased.
You shouldn't leave lipo when charging but if some safely (fireproof safe etc) there is an advantage because you can set both charging overnight.
I balance charge my lipos eve time but every 3-5 tine is okay I think.
To charge both you will need a balance board but given the low power if your charger why not buy another 50w charger. V cheap
My Feedback: (325)
If I had your setup I would charge them in parallel (if they are both 2s packs) and use the equinox "on the side" so to speak. 1 balancer can easily keep up with multiple packs since it doesn't have to work. If you don't like this then ultimately they have to be wired up like http://www.scriptasylum.com/rc_speed/lipo.html shows.
ps. The two outer pins on equinox are also the main leads.
MN
ORIGINAL: Goldenduff
Goldenduff, The packs are 50c discharge, 5c charge so I'm already charging as fast as I can with the power supply and charger I have...which is only 1c. I actually figured if the ChARGER WAS SET TO 4S (14.8) AT 5A INSTEAD OF 2S AT 5A that each cell would still get 5a and charge at the 1c rate simultaneaously? I'm confused as this seems like what I am doing with the equinox already (Charging cells seperately through balancer but with the charger set at a voltage that is the sum of the cells voltage, If I were just from the positive to one neg balance lead(no balancer) I would need to set to 4.2v 5a to charge just one cell, to add a second cell tap and balancer and charge 2 together I set to 8.4v 5a , why not for 4 cells 14.8v 5a with four cell taps??)and that the equinox somehow splits the voltage into 1/4s to make 4x 4.2v5a circuits or something? I mean if I wired the packs in series I could charge at 14.8v 5a? with the same setup and charge twice as much battery in the same time right?
Your charger is the weakest link. If you are already charging at its maximum output you cannot go any faster. what is the max power output of your charger?
I think that you are trying to increase the chargers power output by increasing its voltage? If it is limited to 50w then increasing voltage to 14.8v will drop your max amps to a little over 3amps.
ME
Just to piggy back on what Golden is saying, to show you what he means, we use this equation.
Amps X Volts = Watts
Now we know your charger is limited to 50 watts and we know your trying to charge your batteries at 14.8v (4s lipo) so now we can find out how many amps your charger will be able to use, to do so.
50watts/ 14.8volts= 3.4 volts (rounded up)
So with 4s, your charger will only be able to charge at 3.4amps max, slower than your 5amp charge for 2s but still slightly quicker than charging both 2s lipos one after the other.
Exactly. I haven't looked at the specs of the charger do I don't know it's only a 50w one but it is common....
ME
14.8volts X 5amps= 74 watts
As long as you power supply, for your charger, can produce about 75+ watts you could charge them as a 4s in an hour. Since your batteries are rated for a 5c charge you could actually charge them at more amps (and short charge time) if your power supply can handle it.
MN
I understand the maximum wattage thing, but My charger CAN charge a 4s at 5A so I don't really follow that the charger would not be able to charge 4 cells at 5A just because they are in different packs?
Mostly what I am looking for is how one would wire the harness to do so? Do the balance taps just attach to the series circuit of the cells between ones + and the next - ? I'm assuming the charger just puts out voltage equal to the sum of the cells together, and that when the resistance (determined by cell state of charge and differential between battery voltage and charging voltage) is equal each cell gets a equal amount of voltage across it? Does the balancer just provide additional path to closed circuit between the cells to alter the path and how much each cell sees? Does the adaptor circuit I described initially seem correct? I'll draw a diagram. I think my power supply is actually my weak link as it is rated at 3Amps(old radio shack box), but it has put out 10+amps many times with no voltage drop or blown fuses so I'm assuming if it will maintain 13.75 under the load its not stopping me? Thanks, Todd
MN
is this correct as far as pin connections? The photo is how I am currently charging these packs singly. the black plug is for discharging.
1 Post
16.8V x 5 = 84W well within spec at 1C
If the lipos are more than 1C. I think its an 8A charger, then you can charge at 7A for about a 50min charge.
Charging a 4S at 7.1A will be MAX and will push the charger.
for a 120W charger you should look at 150W power supply.
You should look at 25% higher Watt for a power supply than the charger.
MN
Sorry, now I'm thinking this is the way and that the cells all need to be in series to charge as 4s? Anyone know why all the balance adapters have two red wires? One at the far end and one at the pin following the number of blacks? Thanks
My Feedback: (325)
I see that you are trying to take advantage of the charger's max power because you already have the current maxxed out. This a perfect idea and will work fine as long as the two packs require the same amount of charge.
My Feedback: (325)
ORIGINAL: guver
If I had your setup I would charge them in parallel (if they are both 2s packs) and use the equinox ''on the side'' so to speak. 1 balancer can easily keep up with multiple packs since it doesn't have to work. If you don't like this then ultimately they have to be wired up like http://www.scriptasylum.com/rc_speed/lipo.html shows.
I changed my other mind. IF the packs required the same amont of charge then I'd consider doing them at 8 amps in series using the equinox "on the side"
MN
Thanks Guver...the packs are identical and bought the same time and with the same regularity/duration. The more I think about it I'm considering just leaving the balancer out of the equation and just balance charging every few times when I'm not running my truck right then and don't need to get them charged quickly. If I added the balancer to one pack while charging in series through the main leads it seems like it might slightly increase amperage through the other pack?
I'm thinking about just adding 1 double ended banana plug lead to go from + to - and charging in series. I have just figured out that if you tell the ICE that you are charging a larger than 5000mah battery it will charge as fast as 8 amps...which seeing as the batteries can charge at 5c and most of the charge time will be at a lower current because of the charger limiting voltage I think might be ok. As the charger limits voltage to 4.2 per cell anyway I don't see how it could be any more risky.
I may just make a series lead and charge simultaneously at 14.8v and 8Amps and when I'm not in a hurry either passively balance or balance charge individually at .5c to 1c. I guess if I went and blew about $75 bucks on one more battery and another charger I might not have to do this....but its just too easy to "75bucks" yourself to death in this hobby Todd
MN
As far as a power supply I dont plan on changing until it starts popping fuses, smoking, or the charger tells me input voltage is insufficient. Is this wrong? I'm a "If it aint broke" kind of guy. I'm familiar with the "rules of thumb" and calculations...but I know sometimes this can be a distraction from reality and what is really sufficient. Did you know a average horse can make 14 horsepower in bursts? lol Todd
My Feedback: (325)
ORIGINAL: Max_Power
I may just make a series lead and charge simultaneously at 14.8v and 8Amps and when I'm not in a hurry either passively balance or balance charge individually at .5c to 1c. I guess if I went and blew about $75 bucks on one more battery and another charger I might not have to do this....but its just too easy to ''75bucks'' yourself to death in this hobby Todd
You are correct that using the balancer on only 1 pack may reduce the effective charge to that same pack. You are also correct about lieing to the charger about capacity to allow it to charge at 8 amps. As a safety precaution we can set the max % to about 63%
My Feedback: (325)
ORIGINAL: Max_Power
As far as a power supply I dont plan on changing until it starts popping fuses, smoking, or the charger tells me input voltage is insufficient. Is this wrong? I'm a ''If it aint broke'' kind of guy. I'm familiar with the ''rules of thumb'' and calculations...but I know sometimes this can be a distraction from reality and what is really sufficient. Did you know a average horse can make 14 horsepower in bursts? lol Todd
TX
The 5 amp output is a total output capacity.
If you have 1, 2, 3 or 4 packs it is still 5 amps divided into the number of packs.
You need to use 1 balancer per pack. The main problem (BIG PROBLEM) is that if 1 pack is dead and the other is charged and you are not using balancer then you will more than likely have a problem as the charger will either false peak or continue to charge the full pack.
Do you like big puffy marshmallows? You will have one if the charger doesn't stop when the battery ask it to do so.
At the very least you will hurt a battery. If it is really bad it can all burn down.
Be safe and charge 1 at a time at the max allowed by the charger and the battery pack specs.
Be smart, it is cheaper in the long run.....
Good Luck
MN
I'm still confusecd Handiman? How is charging 2 2s packs in series more dangerous than charging 1 4s pack if we are assuming there is no balancer? Does the charger know that the 1 wire isnt inside the case? In the scenario I am suggesting the voltage is increased for the 4 cells and they are in series, so isnt the amperage still 5 amps per cell? If it is in series the current at any point in the circuit should be the same as at any other point ?Its like saying 5 gallons could be flowing out the end of a water hose but only 2 gallons leaving the spicket isnt it? How can more current flow through 1 part of the same circuit? If I were charging in parallel at 3.7 voklts the current would be divided by the number of cells but? The charger "specs" are good for 4 cells at 8 amps? The batteries are rated to 4.2 per cell at up to 25 amps. I'm not trying to dispute you, just trying to understand. Todd
ORIGINAL: Max_Power
Lesson learned: If you have a 40 Amp charger, do not use a 25A power source:-) Now, if you need more "juice" you can a) connect 2 power supplies in parallel, or if the charger allows, you can connect 2 power 12V sources in series (and have 24V).
Good luck. Proceed with care, and remember you can also smoke the power source:-)
Gerry
1 Post
4s would be at 7.1A with the charger you have, Without any losses inside the charger.
I have to admit without a balancer keeping an eye on the cells i wouldn't try
TX
Let me say, I didn't look up the specs on the ICE> I used 5 amps as a number. If it should be 7 so be it. I have used a ICE charger when I raced cars and trucks. I have been flying for the last 2 years and I was away from cars and trucks a year before that.
Ok so back to your question Max_Power, you are charging 2 - 2 cell batteries in series with out a balancer.
Do you use the batteries in that manner?
If you use them at separate times then more than likely they are at different levels of charge/discharged.
When using a 4 cell pack those cells learn to work with each other and they charge and discharge at the same rate.
They are a "team" in a sense. That is how they are different from your 2 2 cell packs.
When you use a balancer it allows all the cells to charge correctly. The balancers will not manage the balancing correctly if the cells are more than .2 volts difference. Your 2 packs will be that different from each other.
Also with 4 cells in series your charger is looking at 16.8 volts as a max voltage. If 3 cells are full and 1 cell is almost dead or going bad then you could have - 3 cells @ 4.2 volts each = 12.6 volts and the 4th cell @ 3.2 volts for 15.8 volts so the charger is going full bore until that 16.8 volts.
Take a wild guess what might happen to those 3 fully charged cells? Or your shop/house while you watch TV or run to the store.
The ICE charger is a good mid/low level charger. It is old technology when comparing to a lot of the chargers out there now.
Use it with in its limits and don't take chances. You need a good balancer when charging any LIPO or LIFE type of batteries.
With a balancer you should be ok.
Also it it 5 amps total, NOT per cell.
I have 6 packs with 3 cells each for my airplane. I charge them at 6 amps.
That would means I could get my 6 amp output with a 30 power supply to output 108 amps. NOT. It is 5 divided by 4 = 1.25 amps to each cell. Sorry
Also the 4.2 volts is the cell max voltage. When it is higher it is going bad. And don't let it below 3.1 volts as 3.0 volts is very bad. Very.
Now all of this being said the chemistry is getting better every second every day. Most of the cells made in the last year (NOT purchased) are better and probably won't catch fire when abused. Remember the battery is a chemical so it is like a flare when it burns. Have you ever tried to stop a flare when it is burning. Almost impossible to stop.
I hope this helps some.
Good Luck.
