Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Need help with charger settings on my Lead Acid battery
Reply
Old 06-06-2012, 12:41 PM
Flyboy1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Need help with charger settings on my Lead Acid battery
I was just wondering what settings I should be using on my icharger 206B with my Hanger 9 12v 7Ah sealed battery? I set the charger for PB and when I plug in 12V it comes up as a 6 cell battery, which I guess it is then. Now for the charge rate, should I be using .70mAh or 7.0 or what? I charged it for about 45 minutes using .70mAh and it still seems almost dead. I don't know much about charging or batteries. Thanks.
Flyboy1958 is offline
Old 06-06-2012, 12:42 PM
Flyboy1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Need help with charger settings on my Lead Acid battery
My wall wart charger doesn't work any longer.
Old 06-06-2012, 01:09 PM
Goldenduff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
700mah
You might have the peak detection set too sensitively- basically the charger prematurely detects a peak voltage and stops charging.
Try charging at 700mah for 10hrs or so, should get around 13-14v when fully charged I think!
Goldenduff is offline
Old 06-06-2012, 01:32 PM
Flyboy1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just looked at the charger screen again and it is set at .70 A I thought it was mAh but it just says A for amps I guess. So should I set it at 7.0 A ?
Old 06-06-2012, 01:38 PM
Goldenduff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No! Charging at 7amps is charging at 1C, you need to charge at 0.1C so 0.1C x 7000mah= 700mah. That's 0.7amps. Should take around 10hrs.
Old 06-06-2012, 05:09 PM
Flyboy1958
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, I set the charger at .70A so I'll see how that goes.
Old 06-07-2012, 04:53 AM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, set it at 0.1C or 0.7amps. you will ruin a Pb if you charge it to fast. You should not have to worry about overcharge as your charger, if designed to charge Pb cells, will limit the voltage it gets charged to. This will be about 13.7volts for a 6 cell battery.
Rodney is offline
Reply
Display Modes
