Go Back  RCU Forums > Radios, Batteries, Clubhouse and more > Batteries & Chargers
Reload this Page >
Best charger for A123 LiFe packs
Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Old 06-15-2012, 06:16 PM
Peter_OZ
Banned
Default Best charger for A123 LiFe packs
Folks,
I am just venturing into using A123 LiFe packs, 2S for both RX and Ingination use. So far have only one pack in use on ignotion.
I have a Quattro charger that is supposed to be able to handle LiFe however I do not know if it correctly will charge a A123 pack. I did a balance charge, seem to read the pack voltage correctly and charged but only a small amount. So I thought I would do a low current discharge, 250mA and only got about 400 out of it.
Either the pack is crap or my charger is crap.
To be honest I don't trust the Quattro, it does a few weird things with other battery packs, NiCd and NiMh.
So the $64 question is: best charger for a A123 pack. If it has multiple ports to charge multiple packs at once then great. Seems the newer Generation 2 chargers are the way to go but have no idea which one etc.
It must be able to do A123 packs, not just general LiFe packs.
anyone out there actually know?
Not interested in conjecture.
thanks
Cheers
Peter
Old 06-15-2012, 07:29 PM
TheWoodCrafter
Default RE: Best charger for A123 LiFe packs
Any modern LiPO charger will charge a LiFe.
I wouldn't consider anything but iCharger or PowerLabs.
Old 06-16-2012, 04:59 AM
pilotpete2
pilotpete2's Avatar
You can answer the $64 question for just about that price, which is roughly what the FMA Multi4 goes for. The FMA Powerlabs are fabulous chargers, but overkill for charging 2S A123 packs.
Pete
Old 06-16-2012, 05:30 AM
OldRookie
My Feedback: (13)
I would recommend the Cellpro Multi4, or the Cellpro 4S Gold.
I have an old 4S and the Multi4, and both work well for the LIFE chemistry. This charger also charges LiPoly, LiIon, LiFePO4, A123, LiMn, NiCd, NiMH, Pb.
Be aware that there is a difference between the A123 and the generic LIFE packs. I have been using A123 for over 5 years now without a problem. I would never go back to NiCd, or NiMH to power my planes.
Greg
Old 06-16-2012, 06:40 AM
pilotpete2
pilotpete2's Avatar
+1!
One big advantage of the Multi4 over the classic Cellpro4's, is that you can change the current to a lower level than the default 4A on the Cellpro4's. This allows safely charging through a heavy duty switch/charge jack (3 wire DSC) without overheating the standard servo connections with a constant 4A charge rate.
Pete
Old 06-16-2012, 10:19 AM
ALWAYSPDG
I also have the Multi 4 FMA charger and use it for all my batteries and it works great! I would recommend the Multi 4, easy to use too.
Mike
Old 06-16-2012, 12:40 PM
snir2001
snir2001's Avatar
I charge my batteries (A123 systems) with MegaPower infinity 960SR and I got a new iCharger 208B.
I would strongly recommend you to go for the iCharger. it's a great charger! powerful and accurate.
You can find it on Ebay, or to go with HobbyKing for the best price. (I got it from them).
http://www.hobbyking.com/hobbyking/s...e_Charger.html
Old 06-16-2012, 12:51 PM
BarracudaHockey
BarracudaHockey's Avatar
Cell Pro
Old 06-17-2012, 12:53 AM
Goldenduff
Hello and apologies if slightly off topic and for reprdoducing this post (there are many on RCU about chargers). I am looking a for the cheapest charger that measures Internal Resistance, I appreciate that the IR feature is more of an "up-market" feature so cheapest might not be cheap! I am struggling to do a comprehensive search becuase many chargers that do measure IR do not list this as a feature on many websites they are advertised on. Thanks
Old 06-17-2012, 01:26 AM
Gtarling
Goldenduff - if you're serious about measuring the IR of your batteries, you can do no better than one of Wayne Giles' [link]http://www.rcgroups.com/forums/showthread.php?t=1323465&highlight=wayn[/link] ESR/IR meters. They are reasonably priced and very accurate. If you care to read his thread, you'll find that IR is heavily dependent on cell temperature, so you need to ensure you are doing your measurements at a consistent temperature, something which isn't so easy with a charger.
Old 06-17-2012, 03:03 AM
Goldenduff
Thanks Gstarling, have sent a pm to Wayne...................
Old 06-17-2012, 04:39 AM
K-Bob
ORIGINAL: snir2001
Ah, the imfamous four button Chinese chargers. Assembled and manufactered on several brand names, they are all essentially the same under the hood. They do a rather poor job of balancing individual cells and can create more imbalanced packs than they help. I frequently use my Cell Pro Multi-4 to rebalance/balance packs for people who use these chargers.
Do yourself a favor and spend a little more and get a quality charger.
Old 06-17-2012, 07:52 AM
Goldenduff
The i charger is a reputable charger?!
Old 06-17-2012, 05:03 PM
Peter_OZ
Banned
thanks for all your feedback and advice guys.
I eneded up getting one of these:
Cellpro 10XP, 15A Multi Chemistry Charger
Now all I need is a suitable powersupply! FMA one does not state if it is 110v AC or 240v AC ! Anyone know?
Old 06-18-2012, 05:54 AM
pilotpete2
pilotpete2's Avatar
To be sure, you should E-mail them, but I'm sure that they are all dual voltage units, even though they ship with the standard detachable cord for the 120V NA market.
Pete
Old 06-18-2012, 07:08 AM
MostlyKaos
MostlyKaos's Avatar
K-Bob wrote: "Do yourself a favor and spend a little more and get a quality charger."
K-Bob, Isn't the CellPRO Multi 4 made in Singapore?
Old 06-18-2012, 07:49 AM
vasek
vasek's Avatar
ORIGINAL: MostlyKaos
and what's wrong in being made in Singapore, I ask !?
Old 06-18-2012, 08:22 AM
trax de max
their food is far too spicy
Old 06-18-2012, 10:02 AM
Hill202
My Feedback: (24)
Hill202's Avatar
ORIGINAL: vasek
What kind of charger is that?
Old 06-18-2012, 12:56 PM
Peter_OZ
Banned
been to singapore many, many times, yes spicy food and so are the women!!
I did email them, no reply.
Back to topic I got a 1000w, 80A, 240v power supply from hobby king for $158AUD. That will do the trick
Old 06-19-2012, 07:25 AM
MostlyKaos
MostlyKaos's Avatar
Regarding the CelPro Multi4... Looking on page 17 of the Manual, it indicates an input current of 5 Amps Maximum. What are you guys using as a power source?
Old 06-19-2012, 07:40 AM
ALWAYSPDG
I am using a Radio Shack 12 volt power supply rated at 3 amps that has a 12 volt cigarette plug receptacle in it for easy connection. It works perfect for me. At 3 amps I have been able to charge any of my batteries that I use. The power supply has an off/on button, - & + take offs on the front panel, and is regulated. It is small and fits on my desk without taking up a bunch of room. It powers the Multi 4 without any problems at all.
Mike
Old 06-19-2012, 08:59 AM
BarracudaHockey
We have server power supplies at our field, but I've run it off a variety of power supplies.
At the house I have a 12v MaxxAmps power supply.
Old 06-20-2012, 02:50 PM
Peter_OZ
Banned
the charger arrived yesterday from Revolectrix however it did not come with a manual W T F?? How am I supposed to use this thing without a manual?
Not happy, emailed them, no reply so far.
just got a reply, seems manuals are too big to fit in the box so you have to download and print them out. Which I have just done on works colour laser printer [8D]
Old 06-21-2012, 04:47 AM
snir2001
snir2001's Avatar
ORIGINAL: K-Bob
ORIGINAL: snir2001
No no no, absolutely not the same.
The iCharger is a different manufacturer, and use quality internal components.
It's a well known and well respected charger that doing a better balancing job than my 960SR (The 960SR is actually Robbe Infinity 3...)
