If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 6 of 6
Thread: Hitec X4
  1. #1
    Join Date
    Apr 2002
    New York, NY,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hitec X4
    I am having a problem charging brand new Nimh battery packs to full capacity with the Hitec X4. They come up 800mAh short. What should I set the parameters at for 2700mA 6V and 4.8V battery packs with AA cells?
    Louden Kleer
  2. #2
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hitec X4
    Which parameters are you interested in or which ones are adjustable? You , of course already have the capacity and cell count. The voltage drop can be default (or 5 mv per cell)
    and airplanes were in
  3. #3
    Join Date
    Apr 2002
    New York, NY,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hitec X4
    Thanks for the reply. the parameters I'm interested in are:
    NiMH charge (man or auto?)
    NiMH charge current ?.?A
    NiMH discharge ?.?A ?.?V
    Capacity cutoff on or off? ?mAH
    NiMH Sensitivity D.Peak ?mV/cell
    I"m using 2700mA 4.8V (4 AA cell) and 6.00V (5 AA cell) packs.
    Thanks again
    Louden Kleer
  4. #4
    Join Date
    Apr 2004
    PDX, OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hitec X4
    Do you have the manual for the charger?
  5. #5
    jmcowart's Avatar
    Join Date
    Aug 2011
    Douglasville, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hitec X4
    Charge at C/10 and discharge at C for NiMH packs.
    Keep reading the manual, keep reading the blogs, and search the internet - then confirm everything through personal experience. I think I have ruined two NiMH packs trying to learn the correct settings for the X4 and any battery chemistry. Good luck. Mike.
    Mike
    Douglasville, GA
  6. #6
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Hitec X4
    ORIGINAL: louden
    I''m using 2700mA 4.8V (4 AA cell) and 6.00V (5 AA cell) packs.
    Thanks again
    Louden Kleer
    You can use manual or auto , but if using manual then set the rate to anything between about 200-500 ma
    If you will discharge then the rate can be anything up to around 2 amps with a cutoff range of .8 volts per cell (at 2 amp current) to 1.1 volts per cell (at very low current)
    capacity cut-off can be set to anything higher than 2700 mah at fast rates and 4000 mah for using c/10 rate.
    delta peak can be set to 3-5 mv per cell.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
