HobbyKing XD-6
HobbyKing XD-6
I was wondering if this Charger can Charge at 6 AMP's Per-Port or if it is like the Hitec Charger's where the high the Voltage the pack has the less Amp's it can put out.
I will be using the HobbyKing XD-6 to Charge 4 14.8 Lipo's at a time and I would like to be able to Charge them at 5 Amp's each all at the sametime.
http://www.hobbyking.com/hobbyking/s..._4_X_60W_.html
RE: HobbyKing XD-6
It says 6amps per port and 60w per port.
If charging 15v lipos the max amps you can use per port is 60w/15v= 4amps.
Power (w) = volts (v) x amps (a).
I think HK have a 400w x2 port charger. Not sure what its max amps per port is.
All the best
RE: HobbyKing XD-6
From what I'm seeing from the way you figured out the Amp's the XD-6 can put out that would mean the XD-6 can charge Pack's faster then the HK Quattro 4X6s Correct.
Check oout these links and tell me if I'm correct.
http://www.hobbyking.com/hobbyking/s...i_Charger.html
ORIGINAL: Goldenduff
All the best
RE: HobbyKing XD-6
Yes correct. But neither are particularly powerful chargers.
I you have 6000mah (6amp) batteries you can only just charge tem at 1c with the first charger. Many lipos can be charged at higher rates- especially u you stay in the hobby long enough.
I would get a slightly more expensive turnigy 400w- possibly even the dual port one or even get parrallel chargin boards:
RE: HobbyKing XD-6
Goldenduff I was wondering if the IMAX b6 Quattro is the same Charger as the HK b6 Quattro I know there are a few different model's with that same case and I'm not farmiliar with the IMAX stuff.
I sent you an email as well asking you something else.
RE: HobbyKing XD-6
It's funny that the XD-6 Cost's less then the HK b6 Quattro Charger and yet the HK XD-6 can supply more Amp's.
