Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
post you charging set up
Old 10-20-2012, 03:16 PM
trax de max
Default post you charging set up
Ive seen this before and like the idea, which gives tips to people building charging boxes, where the charger and supply is stored and used. I'm half way through mine just figuring out where to put the fans and finish off where to put board.So some of your ideas could come in useful for others.
24V Supplies
maybe this in upper part.
or something like this somehow.
Old 10-20-2012, 05:11 PM
flyallday
Default RE: post you charging set up
Making a charging station has made charging a pleasure. Good idea for a thread. Here is what I have done.
Harry
ID:	1813150   Click image for larger version
ID:	1813151   Click image for larger version
ID:	1813152   Click image for larger version
Old 10-21-2012, 04:33 AM
trax de max
cool, i like the idea of the sheet above the supplies, I think i might go for that.
Old 10-21-2012, 07:20 AM
flyallday
The plex has a gap all the way around that lets airflow in and I didn't have to put any additional fans in. Even pumping out 45 amps, the supplies barely get warm.
Harry
Old 10-21-2012, 12:25 PM
trax de max
I like the idea of that and looks clean too, maybe add my inlet power sockets to the box side and not on top of the supply top.
thank you one reply and picked up some good ideas.
Old 10-21-2012, 12:32 PM
flyallday
This was a fun project for me. I used an external plug / switch that the main power cord plugs into.
Harry
Old 10-22-2012, 08:59 AM
Tombsy
Tombsy's Avatar
ORIGINAL: trax de max
24V Supplies
Mine is quite similar to yours, PL6, 24v 47amp. I replaced the tray with pexi and have the plug, switch and fan mounted in the case.
Old 10-22-2012, 09:50 AM
trax de max
sweet, during the weekend I can get back into it too finish it off.
Old 11-13-2012, 10:02 AM
trax de max
well got round to fitting the fans. Both powered from the supply. Still need a little more work but this is the idea.
Input fan at near bottom on charger side.
Old PCI slot extract fan on power supply side.
Old 03-25-2013, 03:46 PM
rubberman
Ok here is my power supply/charging setup. I dont have my charger yet but it will sit in the top tray.
built in USB port to charge phone or whatever
Rear mounted fan
Top tray with left side dual 12v posts.
power supply in bottom with the external fan
