If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
  1. #1
    scale only 4 me's Avatar
    Join Date
    Jan 2002
    Avon Lake, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    scary find in the shop today
    I was cleaning up and look down and find this battery carrier had melted down, I kept this around to use during set up and I guess apparently lat time I unplugged it from the switch the wires pulled away from the plug. When I picked it up it was cold, but wet with condensation.. Kinda freaked me out.
    Scary thing is I can't remember how long it's been sitting this way, no obvious arcing or burns at the leads, and each cell is over 1.3 volts, low but not dead. I'm dumbfounded that it could melt down the carrier but the cells still have voltage.
    Just shows, need to take caution with all chemistries
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1814137   Click image for larger version.
ID:	1814138   Click image for larger version.
ID:	1814139   Click image for larger version.
ID:	1814140   Click image for larger version.
    You're so smart,, you figured out how to read this!! Or maybe ya just got lucky??
  2. #2
    Join Date
    Jul 2010
    Aberdeen, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: scary find in the shop today
    perhaps its a small acid leak that has burnt the casing. not electrical heat?
    Happy Landings
  3. #3
    Join Date
    Jan 2002
    Avon Lake, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I don't think so, every corner with the spring (-) side is melted, not eaten away from acid, no evidence of acid coming out either, just condensation and electrolysis type corrosion.
    What looks like happened is it shorted, got hot, melted the plastic to the point it lost good contact with one cell, but still enough to conduct some voltage. When I check the packs voltage at the lead it was under 1 volt, but I test each cell individually their all around 1.3 to 1.4 volts
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
