If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2012
    baltimore, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Charging 2 batteries
    Hey guys. I use the traxxas 6 amp charger and i also bought the dual 2 cell lipo balance board, which will allow me to charge 2 lipos at the same time. To set it up you just input into th charger like your charging a 4 cell battery to charge the two 2 cell batteries. But what do i input for the amps? I will be charging a 3200mah and a 4000mah batterry, so obviously one charges at 3.2 amps and the other is 4 amps. I would assume i just charge both a 3.2 amps, but if i do this will my 4000mah battery be fully charged at the end of the charging cycle?
    Atomik MM450, Traxxas Slayer Pro & Rustler, Blade Mcpx & CX2
  2. #2
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Charging 2 batteries
    It is simply a parallel connector so the pack becomes a 2s x 7.2 ah pack. If you were able to set it to 7.2 amps then one pack would get about 3.2 amps and the other pack will get about 4 amps.
    and airplanes were in
  3. #3
    Join Date
    Aug 2012
    baltimore, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So what happens if i just set it the 6 amps? The batteries will both get fully charged correct?
  4. #4
    Join Date
    Oct 2010
    newcastle, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i'm sure the traxxas connector is a series adaptor, not a para type. I may be wrong but i'm quite sure they have 2x2s and 2x3s types.
    Your batteries have to be identical and in pretty much same condition.
    It can do either 2x2s charged as a 4s and the other board can do 2x3s charged as a 6s, but there isn't one for other combination sizes.
    Sorry officer i thought the speed limit only applied to people with driving licenses.
  5. #5
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: j0e331
    Yes, it will be fine.
  6. #6
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: trax de max
    I have never seen nor used one and by looking at the pic it could be series or parallel. Since it's calling for either a pair of 2s packs OR for the other adapter calling for a pair of 3s packs then I assume it is a parallel adapter. It is following the only parallel rule , that is that the packs must contain the same number of (series) cells.
    If it followed the only series rule , that is the packs require the same amount of capacity then I'd say it's a series adapter.
    We will verify by looking at the manual.
  7. #7
    Join Date
    Aug 2012
    baltimore, MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well i will say that i read every word in the manual and it says nothing about the batteries needing to be the same MaH rating. The only thing it mentions about charging is to charge the batteries as a 4s lipo and they recommend charging at 1C (which is a given)
    So my problem is, what is 1C of the two batteries? Do you combine them? This is where im lost
  8. #8
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    A 4s would indicate a series adapter. When cells are in series the capacity remains the same. When in parallel it adds. I'd do some continuity checking on the adapter since there some conflicting info about it. It would be easy to plug both packs in and then simply measure the 2 main leads for voltage.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
