LiPo Tx Pack
RE: LiPo Tx Pack
Ed, It can be done, but to do it safely, you will need to add an in-line voltage regulator to the battery. The 11.1 volts coming from the 3s will over heat the internal voltage regulator in the Tx.
Secondly, you will need to charge the LiPo externally of the Tx case. The on board Tx charger will not charge the LiPo.
Frank
Frank
RE: LiPo Tx Pack
A diode will not drop voltage, it will only prevent you from reversing the polarity. A resister drops the voltage.
A voltage regulator is needed.
Frank
Frank
RE: LiPo Tx Pack
ORIGINAL: Ed_Moorman
Has anyone used a LiPo transmitter pack like the Turnigy 2650, 3S, 1C tx pack in a JR 9303?
Any problems?
Any problems?
How are you doing these days? Now you are far more versed in all this Lipo stuff than I will ever be or care to be. Yet, I would ask these questions:
1. Why LIPO when there are so many very good choices of STABLE batteries that have a lot less chances of blowing up in one's face?
2. Lithium Ion is far better than LiPo. Lith. Ion is far easier to work with. A Couple weeks ago I saw a guy bringing out two of the what are they called the rather new kids on the street, Li-fe or whatever. He was taking two out of an airplane a WHOOSH, smoke and fire for a couple seconds. I have seen several airplanes destroyed with LiPo packs. But then I do NOT do electrics, so don't really know much about that.
There is the A-123 whatever that is. In addition for a transmitter , it seems that the NiCads and NiMah are as good as one can get. I know how to handle them and there I stay, except for the Lith-Ion. I am using a number of them in airplanes. Charge one up, let it sit for a month, pick it up and go fly. I have several pulse chargers and the NiCads, NiMah are always ready to go. Charge 'em, set 'em on pulse and go fly when the call arises.
Good luck however you go. LiPo in a transmitter scares me. Kind of like early Lap-Tops use to be. [:@] Ya'll be careful out there.
ON, CANADA
RE: LiPo Tx Pack
Read up on diodes and you'll find they'll drop the voltage by about .7 volts. and you do have to put them in the right way around. The diode is only for insurance. Many are being used without it. The guy that pulled the batt out of the plane obviously pulled on the wires and shorted it out. A nicad or nimh would do the same thing if you shorted it out. Many guys are using the A123/li-fe which are the same batt. They are 3.2 volts per cell as opposed to 3.7 for the lipo/li-ion, so don't need a regulator. My DX8 has a 4000 ma lipo but comes with a nimh. The trans has a built in charger that can be programmed to charge either one. And I do fly electric and stay at a Holiday Inn
My Feedback: (13)
MN
RE: LiPo Tx Pack
ORIGINAL: Flypaper 2
Greg
My Feedback: (13)
MN
RE: LiPo Tx Pack
You are correct that A123 is a brand name, but the A123 will also out preform a standard LiFe battery every time. That is why when the nano technology was developed at MIT, they got a patent on it.
On standard LiFe batteries, the molecules on the negative plate are all end to end. On the A123 all of the molecules stand up on end like a shag carpet giving the plate more surface area allowing these cells to charge faster, discharge faster, and the negative plate of the battery outlasts standard LiFE batteries, thus a longer life and more recharges.
Greg
Greg
RE: LiPo Tx Pack
ORIGINAL: OldRookie
You are correct that A123 is a brand name, but the A123 will also out preform a standard LiFe battery every time. That is why when this the nano technology was developed at MIT, they got a patent on it.
Greg
Greg
Frank
Frank
RE: LiPo Tx Pack
A diode will drop the voltage if current is flowing through it in the forward direction. How much? Depends on the type and manufacturing structure. Typically a silicon diode will drop about 0.7 volts across it but varies a bit with the amount of current being drawn. Of course it will present an almost complete blockage of current in the other direction until you exceed the breakdown voltage at which time it will either become a virtual short circuit or a completely open circuit.
