If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 10 of 10
  1. #1
    Join Date
    Jan 2002
    Iowa City IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    To many volts?
    Hi gang. I am getting a starter that says it can handle 12 to 18 volts.
    would a LiFe 19.8 Volt hurt the Starter buy just being 1.8 volts over?
    http://www.hobbyking.com/hobbyking/s...arehouse_.html
    There is also another type that is 16.6 volts as well that I could get. I thought about running two 7.2 in series but found these other one's
    So why bother with two battery's? or does running them like that give you a better option?
    Thanks for any help.
    ** CUB BROTHERHOOD ** #90
  2. #2
    Join Date
    Jul 2010
    Aberdeen, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    I would say it would be fine using the life. Amps not volts is the big killer ad the starter will draw the amps it requires.
    Happy Landings
  3. #3
    Join Date
    Jan 2002
    Iowa City IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    Thanks very much for the info,
  4. #4
    Join Date
    Jan 2002
    Iowa City IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    Another Question as I am still confused a bit LOL
    Like the above 19.8 volt $$$ and these below are a bit cheaper
    This starter I am getting is a 6.1 geared ratio. from 12 to 18 volts.
    So I am also looking at the LiFe 4200 MAH @ 30C @ 13.2 volts
    and also the LiFe 4200 MAH @ 30 C @ 16.5 volts.
    So what Will the diff be between all 3 of these for a days use? or power ?
    Would I be just fine with the lesser volts?
    Or maybe the better thing to do, is ask what one would you use?
    Not sure if I am even asking my question right. [] Sorry.
  5. #5
    JNorton's Avatar
    Join Date
    Jan 2002
    Coopersville, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    The higher voltage you supply to a DC motor the faster it spins and the more current drawn. More current less battery life. All your batteries have the same capacity. Seriously - anything you've listed should work. I'd use the highest "C" rated batteries with the highest capacity that will physically fit and stay within the voltage rating of the motor. I never like to push voltage limits.
    John
    Have desk ... Will Fly.... Saito Member #467
    Ultimate Brotherhood #11, Ultra Sport Brotherhood #90
  6. #6
    Join Date
    Jan 2002
    Iowa City IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    Thank You John.
  7. #7
    pilotpete2's Avatar
    Join Date
    Oct 2002
    Lyndonville, VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    Also, remember that the nominal voltage for a lipo (3.7V per cell) is when it's almost outa gas. You should really make your choice based on the fully charged voltage. A 4S pack is 16.8 fully charged, so a good choice for this application, a 6S pack would be 25.2V! Spin baby spin!!! Also, since that's a geared starter, you may even be good on 3S.
    As John said, the lower the voltage that's able to do the job, the longer your starter will last.
    Cheers,
    Pete
    \"If the woman don\'\'\'\'\'\'\'\'t find you handsome, they should at least find you handy\"
    [Red Green]
  8. #8
    Join Date
    Jan 2002
    Iowa City IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    Thanks Pete,
    So I think I will go with this one then?
    http://www.hobbyking.com/hobbyking/s...dproduct=24190
    Good Choice? Remember the starter is already geared at 6.1
    this one is at 16.5 volts ( 30C constant and 40C burst )
    Jeff
  9. #9
    pilotpete2's Avatar
    Join Date
    Oct 2002
    Lyndonville, VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    not really 16.5V, but actually 21V fully charged. Don't be misled by the nominal voltage rating of batteries
    Pete
    [Red Green]
  10. #10
    Join Date
    Jan 2002
    Iowa City IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: To many volts?
    Got'Er Done.... Thanks Guys.. even used the project box.
    Kicks BUTT !
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1847642   Click image for larger version.
ID:	1847643   Click image for larger version.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
