Cellpro 10S & Honda Generator
I have a Honda 1000 watt generator with an inverter .
On the face of it is a recepticule that says 12 volts DC.
Can I use this port to power my cellpro 10 charger with having a power supply in between.
Of course the power supply unit would use the 120 volt ac .
My Feedback: (10)
RE: Cellpro 10S & Honda Generator
Read your Generator Manual; if it says that the outlet you are referencing is for 12 Volt DC 'OUTPUT' than it should work for your Cellpro; the other thing is to see if it is 5 Amp output, I believe that's what your Cellpro requires; the reason I say check your Manual, I have a small Honda 600W Generator with a 12 Volt outlet, but that is for Charging a 12 Volt Battery like in your Car, Truck, Tractor, etc; Also, I don't believe you can use both the 12V DC Outlet and the 120V AC Outlet at the same time; if all fails, just plug your CellPro Power Suopply into the AC outlet on the Generator.
