HV servos with stock RX??
#51
My Feedback: (198)
RE: HV servos with stock RX??
ORIGINAL: Rob2160
Yes that would be possible also.. My question to acerc or anyone who knows the answer.. relates to having two seperate batteries.. one just for the RX.. one for the Servos and no common ground (ie black wire) in this case just plugging in the white wire to the RX - would it control the servos
Genuinely just curious.. I will test it myself when home in a few days..
ORIGINAL: drac1
OK, then you could run a 5 volt regulated power supply from the LiPo to the rx. No need to use a separate battery.
ORIGINAL: Rob2160
The receiver will still need power.. to receive the signal from the TX and generate the signal to the servo..
Without power the RX is just like a mobile phone without a battery.. IE totally dead..
ORIGINAL: drac1
Correct me if I'm wrong, but the rx doesn't require power in this case. The white wire is signal only to tell the servo what to do.
