NiMH Discharging
The only reason for discharging a NiMh or NiCad is to check for capacity. If doing that, discharge at 1/3C or less down to 0.9 volts/cell while measuring mah's. If they are at 80% of rated capacity, they should be good for use in critical applications. Prior to checking for capacity, charge at 0.1C for at least 15 hours, no need to discharge prior to this charge as, at that charge rate, no damage will be done due to overcharge of any cell.
