HELP NEEDED! GT Power A606-D
ON, CANADA
Hello guys, I just converted to Lipo and I needs some help
I got a GT Power A606-D charger and a CRC 2s 7100/90c rocket fuel
I was told by the guys at my LHS to use the Lipo Balance mode at 6.0A and 7.4v
I found the lipo balance setting but I cannot see how change it from 3s to 2s and from .5A to 6A
I also read that there is an auto mode but i cannot find it.
Thank you guys for your help I really appreciate it.
1 Post
the auto mode is for nickel batteries,
What capacity is the lipo your charging.
From memory you just press enter then inc or dec to change the lipo cell count and press enter to change charge rate. the single enter press scrolls through what needs changing a constant hold for a few seconds confirms start.
1 Post
is the balance plug your using matching the chargers balance port, ie XH plug.
If it is the same, there might be a problem using the charger if it's only showing 3 and 6s
That's a nice battery, It's worth getting a better charger. It would be a waste to ruin an expensive pack because the charger isn't as good as it should be.
If you don't have manual here's the link. http://www.4-max.co.uk/pdf/GTP-A606Dmanual.pdf
