I have no clue on how to select a Lipo battery for a particular setup, please help.
So as the title says, I do not know how to select a battery for the setup. I tried to do research and was not able to find what I was looking for. I am trying to set up an upgrade motor/esc/battery for an RC plane. I am looking to use a NTM Prop Drive Series 35-36A 1400Kv / 550W with a Hobby King 60A ESC 4A UBEC for my Tower Hobbies brand P-51 Mustang. A while back I nosed the Mustang and wrecked the motor mount. I flew a lot more since the wreck and consider myself an OK pilot. I own several planes and fly them well, so I think I am up to the task for the upgrade for my wrecked plane.
Thanks in advance,
Mark
Thanks in advance,
Mark
I'm not understanding fully about selection problem. Maybe I'll learn here also...
Last edited by RustyUs; 11-03-2014 at 05:52 PM. Reason: not understanding about not understanding
E Clc (propeller) is a likely way to investigate with.
You will need
weight, wing area, and propeller type/size
The motor specs KV etc.
The ESC current and voltage ratings
Basically, this tells you what the ~ behavior should be.
You will need
