How many amps can I charge my battery at?
I have this battery.
It's a 4000mAh 2s lipo battery. It claims it has a 25c constant and 35c burst for discharge. I have my charger setup at 2 amps at 7.4v, but figure it can probably handle more than that. So what's a good amperage figure to get a fast charge without risking damage to the battery?
TIA
TIA
1 Post
Balance charge at 4A.
it claims to have a 5C charge rate, which will be 20A, but I'd stick to 4A which is 1C.
http://hobbyking.com/hobbyking/store...arehouse_.html
My Feedback: (20)
TIA
TIA
you could charge that pack faster at 2C without issues
Thanks guys.
On another note, I think I was able to bring a battery back from the dead. My charger was giving me the low voltage warning...which meant I was down to 1 of 2 cells (at least that was the case with one of my other batteries). Anyways...put it a manual nimh charge at a very low amperage (I think 1.0 if I remember correctly) and the 7.4v rating. Let it charge for about 10 minutes, and then switched back to the LiPo setting. Charged properly without any errors after the short manual charge....wonder why that happened?
Guest
For most stock lipo's you get with a RTF model, you should charge them at 1C, or 2200mah lipo at 2.2 amps. BUT! My 6S 3300mah Nano-Tech has such a high maximum charge on the website, i can charge it at my chargers max rate of 5amps with the only problem/danger being my old charger getting a little hot! You should check a website such as hobbyking were they are sold to be certain you are not putting yourself, or your RC's in danger.
Also, with that lipo... eeeehhhhhh. Good luck! I know i"m always very cautious with lipo's, life's, or lion's, but i have seen what one can do to many times before.
- Ethan.H
- Ethan.H
For the longest life you should charge at 1C but for quick charge 2-3C would be o.k. Once you kill a lipo you will always have an issue with the damaged cell staying balanced. Mind the cut off voltage and you won't have a problem.
Thanks guys.
Usually, further testing will show that the over discharged cell has less usable capacity than the other cells in the same battery.
This means that the battery capacity and current capability are determined by the weakest cell.
