re: Charger choice selection from a noob.
Hello all. Trying to understand all this lipo crap. Here goes. I'm looking at buying 2 smc-racing 2s, 60c, 9000mah batteries for a traxxas e-revo. I'm looking at either the Hobby king quarto 4x6s, the Hitec 4x 80w each, or the Turnigy 4x6s 400w. I want a 4x charger as the e-revo takes 2 batteries to run. Will these chargers eventually handle charging 4 of these batteries at once. I'm not sure if they will because of the wattage they're listed for, and the battery is 9000mah. If they will handle them can anyone tell me a ball park time if will take to charge these batteries from an esc cutoof, and from charging up from a storage charge. Thank you for the help. looking forward to being a member of this forum.
Moderator
What you could do, is get a dual charger and charge them in series. I think that would be a smarter idea as far as efficiency goes, as well as cheaper.
Charger; http://www3.towerhobbies.com/cgi-bin...FYYdgQod0PQPUw
Charge leads (need 2 of these); http://www.rchobbyexplosion.com/Trax...FUskgQod9g4BNA
I don't understand how that's cheaper. As I understand with my basic knowledge, and the more I learn, you can set your charger to 9.0 amp charge rate on a 9000mah lipo battery. If that's the case, and you're charging 4 at once, then you're limited to how much power output the charger can handle. If your charger only outputs 50w per charger port, then on a 9000mah setting you won't actually be charging at 9.0 amps, it will be much lower, because the charger doesn't have enough power to charge at that rate. This in turn slows down your charge time. Not what I'm looking for, I don't want my charge times significantly lowered because the E-revo runs on 2 batteries at once as it is. The more I look, the more I think the Turnigy 4x 400w DC charger is the way to go. From what I see on reviews the charger can handle a dedicated 10 amps. per charger port due to the 100w dedicated per port. I can get that charger for about $130, and a decent 500w+ power supply for $65. Total cost is about $200 plus shipping, plus the extra leads which you would need anyways. I also have the option of charging on location hooking the DC charger to a car battery, and don't have to go through the hassle of charging in series, etc. Is everything I just spouted sound about right, is there any flaws in what I was saying? Let me know what you guys think
Let the website product page sit for a while and you'll get a better deal on Hobby King. And don't forget to get additional balancing leads if you plan on going with the Turnigy.
When I'm balance charging a LiPo pack at a 1C charge rate; from storage voltage, it normally takes around 90 minutes to fully charge.
