Heat shrink size help
My Feedback: (50)
What size heat shrink do I need to rewrap this battery? What is the best source?
[h=2]GForce 25C 4000mAh 2S 7.4V LiPO (Fit TRX Vehicles)[/h]
135mm x 45mm x 17mm (5.3in X 1.8in X 0.7in)
Somebody please correct me if I'm wrong. You would need at least 64mm wide material?
http://www.maxamps.com/products.php?cat=180
Edit: I Think I would order a bit bigger to allow the shrink wrap fit over the pack a little loose.
http://www.maxamps.com/proddetail.php?prod=Shrink-68B
