Help please
If it's one of those mini ones, they usually plug into the handheld controller/transmitter, or plug into a USB port. Otherwise, you'll will need to use appropriate charger for appropriate battery chemistry. Operator's/Instruction manual...I'm sure there is a section in there with guidance on subject. You did read the manual, right?
Hi,
This is a toy-grade coax heli and it looks like it has a wall-wart type charger . Plug the battery into the charger and plug the charger into a wall outlet and as Rusty stated...............read the manual.
http://www.yousky7.com/AK6805-026-he...rts/Index.html
