Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Charge lead for Futaba RX LiFe battery
Reply
Old 06-18-2017, 07:55 AM
Wild Beat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Charge lead for Futaba RX LiFe battery
Hello all,
I'm looking for advice on how to charge futaba FR2F800 type receiver battery. The battery is 2 cell, LiFe PO4 type battery, and is charged through the balance lead (3 wires, black blue and red).
Does anyone know how to creat a charge lead to plug into the a regular type charger? One with regular charge ports and a balance board?
Also, i have two of these batteries in the plane. Is it possible to create one lead to charge the two batteries in parallel?
Thanks for any help you can give!
Wild Beat
Wild Beat is offline
Old 06-19-2017, 08:11 AM
pilotpete2
pilotpete2's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It appears to have the standard JST-HX balance connector.
What charger do you have?
Does you chargers balance board have a 2S JST-HX connector?Pete
pilotpete2 is offline
Old 06-19-2017, 09:52 AM
Wild Beat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Pete! The balance board I'll be using is capable of 6 cells max I think, with only connector per cell count (2S, 3S, 4S...). Yes, it is a HX type connector.
So I just need to know how to: (a) make a charge lead that connects to both the balance board and the balance cable. Is that simply a case of directly soldering the charge leads to the balance cable (pos-to-pos, neg-to-neg?) and (b) see if it possible to make one cable to balance charge (in series or in parallel) the two packs together at the same time.
Thanks for your answer. Wild Beat.
Old 06-22-2017, 03:53 AM
Four Stroker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LiFe or NiMh?
Four Stroker is offline
Reply
Display Modes
