Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Hyperion eoso 606i charging issue
Reply
Old 11-09-2017, 03:24 AM
pooch692000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hyperion eoso 606i charging issue
Have a brand new set of 7.4c/5000mh floureon lipos. Set the huperion charger up for 2s, 5A charge. Connect balancer and leads and hit enter and get “balancer con. connected” then beeping and “check the batt. Low voltage. Balancer is plugged into the 2s balancer adapter. Any ideas? Help
pooch692000 is offline
Old 11-09-2017, 04:00 AM
pooch692000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Photos
Is the adapter in battery corrext for the board? Board has 5 pins and batt adapter has 3 female holes
ID:	2244204   Click image for larger version
Old 11-09-2017, 09:05 AM
pooch692000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default new issue
Charger uses its own hyperion balancer tab. Am using floureon lipos. Moved the femal adapter from battery over so the red wires lines up and it starts charging. However inget the “open circuit message”. Maybe i ned a different adapter from charger aoits compatible with my battery?
Old 11-09-2017, 09:27 AM
Propworn
Propworn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hyperion makes different balance boards that plug into your balance lead. First you have to identify the type of balance plug the battery manufacturer has used then order the right board.
Propworn is offline
Old 11-09-2017, 09:53 AM
pooch692000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. I was just reading and figured it out.
Old 11-09-2017, 10:11 AM
Propworn
Propworn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Good for you its all part of the learning curve. Good luck have fun.
Propworn is offline
Old 11-10-2017, 02:18 PM
pooch692000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can i use a oarallel charging board in this charger?? Want to be able to charge multiple same cell batts at once
Old 11-11-2017, 05:27 AM
Propworn
Propworn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think the output is only 6 amps with that charger. I think you would need at least a charger with 10 amp output to charge two of those 5000 mah packs in one hours time. Any way there is always adaptors out there that allow parallel charging. This link might help to understand parallel charging https://sites.google.com/site/tjingu...allel-charging
Propworn is offline
Old 11-11-2017, 05:47 AM
pooch692000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes only 6 amps and 50 watts. I’d need 84 watts to charge at 10, sonwouks have toncharge at 5.95 amp instead of the 10 for 1c. Also as far as setting the mh on charger do inuse 10,000 or 5000? Not evenaure the charger can go up to 10,000
Old 11-11-2017, 11:05 AM
Propworn
Propworn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use a powerlab 8 with parallel board. I also use two server power supplies in series to give 24 volts at 47 amps.
Revolectrix
Revolectrix
Convert HP server power supply for RC use - TJinTech
I don't know how handy you are at modding the server power supplies but there are guys out there that sell them already done.
Propworn is offline
Reply
Display Modes
