Can I run a 2S lipo with a 13t brushed motor on a Hobbywing QuicRun 1060 ESC
I wanted to run a HobbyWing QuicRun 1060 brushed ESC with a 13t brushed motor and a 2S Lipo, but on the HobbyWing website under specs it says that i can only use motors under 12t with a 2s. Anything more than 12t and i have to use a 3s. Do i have to worry about this, or should I go with my plans (2s lipo/13t motor/QuicRun 1060)?
A 2S LiPo pack and a 13T brushed motor is fine to run on that ESC.
2S LiPo motor usage spec: ≥12T (greater than or equal to)...meaning you can use 12T, 13T, 14T, 15T, 16T,17T....etc. etc.
A 13T motor will produce less RPMs than a 12T motor. A 14T motor will produce less RPMs than a 13T motor. A 15T motor will produce less RPMs than a 14T motor, etc., etc., etc.
