NEED SOME LI-PO HELP
I bought a indoor 3D electric plane. I think it will weight about 5-10oz but not exactly sure. I also bought a GWS twin 7:1 motor. Seeing that I don't know much about Li-Po, except that they are dangerous, i was wondering which battery pack to use. The seller of the plane recommended 3 cell 11.1v 800mah HD and 7 or 8C. I don't no what the 7or 8C means. Is this battery good and what website could i buy one from. Any help or suggestions would be great. Thanks
Also i bought a LPC-400 Li-po charger, is it ok
RE: NEED SOME LI-PO HELP
7 and 8C is 7x800mAh=5.6Ah or 8x800mAh=6.4Ah check a dealer with lithium cells and read the continous draw on the cells and you will se.
Otherwise keep asking and we will try to answer
