Hitec CG-340- how good does it work?
CO
I have had one of these for two years and I have no complaints about it. My Hobbico Quick Field Charger Mkll has started overcharging my radio's AA Nimh batteries when I set the current lower than .5amp so I ordered another 2 of these CG-340's to replace it but I haven't done any precision testing on them. One thing I really like about them is that my batteries never get more than lukewarm so I know it isn't overcharging at all. With a price of $34.99 it's hard to beat.
-Tom
-Tom
TN
RE: Hitec CG-340- how good does it work?
I've had mine for almost 2 years, and have had no complaints. It does what they say it will do. I checked the dial amp setting with my Fluke digital meter and the settings are real close to the marks on the dial. On Ni-Cd the peak voltage is right at 1.45V per cell. Works for me.
Nashcat
Nashcat
CO
Thanks, that's what I wanted to know, if it was doing it's job. I'm going to use three of these as my main means of charging. I have many other chargers but they all require some kind of manual intervention to prevent them from overcharging.
PA
I was just reading the write-up on this at Hitec and they state it has a "Peak Charge" and "Delta Peak Cut Off". Doesn't that mean that there should be no "manual intervention to prevent them from overcharging."? Isn't there a turn it on and leave it kind of charger in the under-$100 range?
Inquiring minds want to know,
CO
I think you misunderstood my last post, I meant that my chargers OTHER than my CG-340 require manual intervention. The CG-340 automatically turns itself off after it peaks the battery.
