Charging with Lipo-502 charger
My Feedback: (9)
NC
Hi
I purchased the Lipo-502 charger and power supply in Toledo this year, along with Kokam 11.1V 1500 mAh batteries.
My question is what is a safe setting at the chargeing rate, I have been using the 1.0 amp setting, can I charge at the 2.5 amp setting, or am I looking at fire danger using that setting?
Thanks in advance
Bill
Thanks in advance
Bill
RE: Charging with Lipo-502 charger
Hi Bill,
You can charge at a rate equal to or less than the pack capacity. In your case, that is 1.5amps or less.
Typically, the charge runs from 30 to 45 minutes.
ORIGINAL: SigMan
my thunder power 425 charger dosent have a mah setting, it has a .05 amp, 1.0 amp and so on, kinda newbie to electrics.
[email protected]
