ace digipulse Help it stopped working
NY
Hi guys need help or input, I bought an ace digipulse last sept, used it at home till nov. when our season suddenly ened due to loss of field. I kept he charger and my other equip. in work shop over the winter now when I tried to use the charger again it does nothing. No self test , only power light comes on. It will not re-set seems frozen . Any ideas . It was not dropped soaked or damaged in any way, Help
Paul
IL
RE: ace digipulse Help it stopped working
If you've installed the 9V memory backup battery,
check it for leakage or short.
Reset to be done with power ON.
Maybe check power output on wall transformer:
24VAC @ 1.8A.
Hope this helps.
24VAC @ 1.8A.
Hope this helps.
