Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
Energizer 2300mAh nicads & charger problems.
Reply
Old 06-12-2005, 03:55 AM
zr1s10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Energizer 2300mAh nicads & charger problems.
Ok so I go to the PX in hopes of a getting some rechargeable batteries for my two cars. So I buy the energizer compact charger
and 16 2300mAh AA nickle-metal hydride.
Well the problem is I let them charge all the way (until the light on the charger turns off). Put em in my JR XR2 controller and it doesnt turn on. It makes the beeping noise but doesnt turn on.
zr1s10 is offline
Old 06-12-2005, 10:28 AM
mbba2002
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Energizer 2300mAh nicads & charger problems.
I have used the Energizer 2500 Nimh batteries but not the charger. I make my own packs out of the batteries. Then I use my tekin 112c to charge all my batteries. I have had no problems with the batteries.
mbba2002 is offline
Old 06-12-2005, 09:20 PM
zr1s10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well what I think it is, is these are 1.2v and regular AA's are 1.5 So with 8 batteries its a 2.4volt difference! Could it be the batteries just dont have enough power?
zr1s10 is offline
Old 06-13-2005, 12:05 AM
smokingcrater
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: zr1s10
I haven't met a tx yet that doesn't work fine on nimh.. the voltage difference is a big myth, yes the resting voltage of a alkaline is higher, but it soon drops down to 1.2 volts for normal use, whereas nimh's pretty much stay at that voltage.
my guess is you have a bum cell, take a volt meter and check them out to see if they are all close.
smokingcrater is offline
Old 06-13-2005, 06:14 AM
zr1s10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could it be the charger isnt bringing them to 1.2v?
zr1s10 is offline
Old 06-13-2005, 09:26 AM
mbba2002
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You may have to cycle (charge,discharge) the batteries several times to condition the cells. Try a different set of rechargeable batteries and alkaline batteries to eliminate the problem with another device. I think your batteries falsed charge. That can happen on the first charge.
mbba2002 is offline
Old 06-17-2005, 06:21 AM
zr1s10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: mbbaj2001
Hey you were right!!! Sofar I've got 8 of the 16 to charge. When I put em in my XR3i they put out 9.2v! So the 2300mAh's hold a charger longer than a normal alkaline correct? Cuz I think 9.2v is pretty low?
zr1s10 is offline
Old 06-17-2005, 09:35 AM
mbba2002
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will take while for the voltage to increase to above 10 volts. You are definitely saving money. I have'nt done any testing to see how long a 2500 NIMH battery will last compared to a alkaline battery the same size. But you can do a cost saving chart yourself every time you charge the batteries vrs. buying alkaline batteries for you equipment.
mbba2002 is offline
Old 06-17-2005, 09:52 PM
zr1s10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So they will charge over 1.2v?
zr1s10 is offline
Old 06-18-2005, 09:54 AM
mbba2002
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
YES after several cycles you will see a improvement.
mbba2002 is offline
Reply
Display Modes
