Solar Battery charger???
GA
anyone use solar panels to top off your field battery when out at...the field??
Harbor freight has a couple for pretty cheap, was just curious if anyone does this and if so.... what panels do you use??
Exeter
Exeter
RE: Solar Battery charger???
For what its worth, check out the following:
http://www.rcbay.net/viewmessages.cf...row=31&erow=40
Scroll down to the second entry.
Did a search on RCU and turned up nothing of consequence. Hope you get some good replies.
Steve
PS: If the link above does not work automatically, copy and paste it in your browser's address line.
Steve
Yes it has been done but, it takes a very large solar panel to be of much use. A typical 15 inch square panel will only supply about 300 ma. into 12 volts and then only with bright sunlight and optimum orientation. It is not a practical solution.
