What powersupply should I buy
VA
What would be a good power supply to use for most any shop application as well as with the Multiplex LN-5014 Multi Charger ?
The Tower suggested power unit , Hobbico 12V DC Power Supply with 5V Tap.
It plugs into an AC wall outlet and converts the AC to DC voltage,
so DC chargers can be used in the workshop of your home.
Warning: The 5V tap WILL NOT work with the NEW STOCK COMMUTATOR LATHES
because they draw between 5 and 7 amps. This load WILL OVERLOAD
and damage the 5V tap.
So , Is their a need to look for a more powerful power supply? I have a Accu-Cycle and it doesnt need a seperate power supply. I dont know much about the componets.,the Multiplex LN-5014 was recommended by Red Scoffield who is an expert in batteries and chargers. I dont remember reading anything about the additional power supply needed.
thanks, Bill
This is the Multiplex Multicharger Battery Charger.
FEATURES: Charges 1-14 cell NiCd, 1-14 cell NiMH, 1-5 cell Lithium Polymer or
Lithium Ion and 1-6 cell lead acid batteries
Constant current/constant voltage for Li-Po and Li-Io
Illuminated digital LCD screen displays battery type,
charge/discharge mAh, voltage and charging time
LCD screen will also display error messages for out-of range input
voltage, incorrect connection or reversed polarity, poor battery
condition and internal errors
Adjustable charge current from 0.1-5.0A
Charge, discharge and cycling functions
REQUIRES: Power supply capable of delivering 11-15VDC (HCAP0250)
thanks, Bill
Banned
My Feedback: (9)
RE: What powersupply should I buy
Take a look at any of these, you should get one having at least 8 amp capability.
Here are three on line sources at good prices.
http://www.efunctional.com/new-pyram...-supplies.html
http://www.millionbuy.com/caudio-kit-sup.html
http://www.buyreliant.com/psupplies/...r_supplies.htm
