Nimh for ignition????
Hi all,
I still hav'nt made up my mind on a perminant set up for my twin ingition power supply so up till now i have been using a 1400 mah nicad (AA) for my twin ignition and charging after two 12 min. flights.
Now i have a 2500 mah Nimh (AA). I hav'nt tryed it yet so what can i expect? Is the discharge rate going to be too much for them to handle? Will i be able to top them up at the field quickly enough and not ruin them? I have a 'Swallow' charger that i will be using.
I know Lipo's and a reg is the ideal but we have limited choice in OZ and i hate getting hit with import tax.
Like i said this is a temp set up,,,, just want to know how you think it will go.
Cells are Sanyo and ignition is on my ZDZ80 Twin.
Thanks in advance for any ideas
Brad
Brad
RE: Nimh for ignition????
ORIGINAL: Brad330l
Hi all,
Hi all,
Brad
Brad
Personally I do not believe that a LiPo set up is ideal for ignition. You need a regulator and the cells are much more prone to failures if not properly taken care of. This includes making sure they are fully charged for storage. If you put them away for 6 months they can self discharge below 2.6 volts and self destruct.
My Feedback: (16)
GA
One 1200maH pack should last you for about 60 minutes of run time with no problem. If you are charging after 30 minutes with two packs then something else is wrong.
ORIGINAL: Brad330l
Hi all,
Brad
Hi all,
Brad
Thanks Guys.
I will be sure to 'Form Charge ' my new pack before using it.
What kind of draw would one be looking at from a twin plug ignition?
Would a single 1400Mah AA NiCad really last an hour?
Regards
Brad
Regards
Brad
John,
Sorry for seeming so dumb and putting up with me.
If I start out at say 5.5v with my pack and run it to say 4.8 to 4.7v is that the 1400 or 2500 or what ever Mah for the Battery?
The usable capacity? Flat is flat right and i have run my engine till it misses.
Another way,,,,,1400/1000 = 1.4 hours,,,, is that down to 4.8v or so.
Thanks again
Brad
Thanks again
Brad
My Feedback: (16)
GA
No pack capacity is run at .5c load to 0.9volts.
Pack capacity means nothing other than a rule to masure the health of the pack.
Fly your plane until it is down to 4.8 volts with the engien running or a 1 amp load.
Ignition units draw at different rates but I would say a twin would draw from 800ma to 1000ma of current.
Geistware is right my bad. Using manufacture rated capacity the voltage drops to .9 or 1 volt per cell ie 3.6 or 4.0 volt on the low end. Sorry for the confusion.
A better approach would be time the plane on the ground (paying attention to cooling) until it starts to miss, and give yourself a safety factor.
Here is Sanyo's web site for battery charge and discharge graphs. You can use these to help determine capacity if you know the type of cell and the draw.
http://sanyo.wslogic.com/
John
EDIT -> I truly believe I'm still asleep! Running the plane on the ground till it misses is somewhat impractical, it would work but.... If you just take the current drawn by the ignition divided into the rated battery capacity and then halve the result you should have a good time to work with. 1400 / 1000 = 1.4 hours / 2 = .7 hours or 42 minutes.
John
Thanks Guys, for the lessons and input.
Looks like I have ended up with a simple, light, cheap and effective system.
Manual switch with charge jack $12
Optical/electronic switch $55
2500Mah NiMH AA pack $28
And that's Australian $$$$$$$!!!!!!!
I will be able to get my four or so flights of 15mins with no worries.
Have fun and all the best.
Brad
Brad
