Peak Detection set up?
RE: Peak Detection set up?
No the ratings above are the delta peak settings, not the charge rate (mah) if you want a faster charge, increase the mah/hour (but not too much!)
If you set too high a value it may make the charger less sensitive and you risk over charging and damaging your battery. If you set too low a value it may make the charger more sensitive but you may under charge your battery or get false peaks and it will not charge to it's full capacity.
