digipace 3
NM
Something to look for ?
Check the male pins on your charger receptacles.
You will see that the pin is split. With the charger unplugged, carefully insert a small screwdriver blade in the slotted pin and spread slightly. This will insure a superior contact.
Let us know what happens.
Jim Lynch - Moderator
