Piranha 1900
Piranha 1900
What is the capacity the currnt and the peak for this battery?
it is a piranha 1900 scx 6-cell 7.2 volt battery.Reason being is that my charger asks for that and i dont know what to put?
my charger is a Piranha digital peak charger.
nick
nick
My Feedback: (325)
RE: Piranha 1900
capacity is 1900, put in around 2000 mah. current can be anything between .1-5.0 amps put in 3-5 amps (ac power is limited to 3) and the peak should be set to around 10 mv.
Usually what I do is to try a forming or equalising charge at 200-300ma (.2-.3) for 12-16 hours and then after a few cycles discharge completely and then set the rate to 2-4 amps while setting the capacvity to a very high value. After seeing the capacity that it actually charges to then use that capacity as your input as a safety.
