Single cell and Triton issue..... help
WA
Greetings,
I am having difficulty charging my single cell Nimh glow driver with the Triton. I have all the parameters set well within range, but it continually gives me several false peaks before I get a good and full charge. The false peaks usually happen after only a few mah have been put into the battery, way short of what is needed. Then for some reason after a couple of tries, it will go ahead and give me the full charge as needed. Ideas anyone?
Ernie
Ernie
My Feedback: (325)
RE: Single cell and Triton issue..... help
I would agree, on single cells especially at higher charge rate. nice short fat leads will be a must. You can also possibly bump up the "peak delay at start" function to a huigher time than when it starts behaving. Like 10 minutes or more.
WA
The leads are all new and clean. I am however using an adaptor that plugs into the glow igniter hot end. I will take a look at that; perhaps there is some oil on that end. I do think it has something to do with charging a single cell though?
Ernie
Ernie
My Feedback: (325)
You may try to read voltage as you wiggle connections and that will tell ya. As long as you know your battery cell is drained quite a bit then setting the "peak delay at start" to 15 - 20 minutes is ok if you are chargeing under 2C rate.
