How to charge litium ion?
Hi there!
I must say i am a newbie and i need some help!
I have the Multiplex LN5014 and i'm trying to charge a litium ion pack. When I connect the pack to the charger, i insert the amps (1600mah) and the voltage (10.8volts). Then, the charger says that the battery is already charged. The other option in the voltage menu is 14.4 volts. What am i doing wrong?? Should i put the 14.4 volts instead of 10.8 volts?
Thank you for your expertise!
