Great planes Triton
IN
Great planes Triton
Can anyone explain to me how to set up my triton to charge a three cell LI-PO pack? Its a 900 mah pack. I set the setting at 0.3A and set the voltage at 11.1v... Is this correct? I dont want to be a statistic with the fire department.
IN
RE: Great planes Triton
Yes I have read the instructions but it's all mumbo jumbo to me. I picked .3A because it technically should be a safe rate to charge the pack. From what I gather you shouldn't charge the pack at anything above .9A
A three cell 11.1V 900Mah Li Poly pack should not be charged at nothing higher than .9A and should not be disharged less than 9.0V... Is this correct? thats thd reason i charged at .3A is because I felt it would be a nice cool slow charge.
Looks like you are doing everything correctly. However, you can safely go to a 0.9amps (1C) charge rate on your 900 mah battery if you want to with no danger. The Triton will end the charge when the battery reaches the proper voltage. As you have probably noted, the charge current starts out at a much lower value than you set it to. It then increases to whatever value you programmed in until the battery approaches full charge. The current will then slowly decrease until the battery reaches full charge. At that point charging cuts off and the display displays "END".
IN
The triton does the same thing. At the end of the charge it peaks at 0.0 A. Its starts at like 0.1 and goes all the way up to your setting and slowly reduces to 0.0A at the end of the charge.
