BANTAM chargers
That is the beauty of the PB-5 and PB-6, is that the discharge is 500 mah. Most are 300 mah and others are even less.
Email me if you have any questions.
RC Accessory, Inc.
Auth US Bantam Importer
EDIT: N/M, it took 76 minutes, but it pumped 2300mah into a 2200mah battery, and finally said FULL and beeped when it finished.
What does the charger do when it's done charging? The balancer will go dark, the amps it's charging at will drop to around .3, and the voltage will stop at 12.6, but it seems to just keep trying to charge. I've never let it go long enough to see what happens.
Almost all lipo charges use the cc/cv routine for charging. The charge rate will decrease as the voltage of the pack increases. The last 5% of the pack take a longer time to complete the charge.
If your battery pack is a 2200, you can set the capacity cut off at 2200 and the charger will terminate the charge when that amount of capacity id reached.
RC Accessory, Inc.
I have a impulse POWER battery (2S, 480mAH) sold by hobbypeople.net. I think it has the Align/Dualsky connector type, but I am not sure.
Do you know what type of connector is on it?
I would like to get a Bantam BC5, but I don't know what balancing connection I need.
I just got my BC5, and want to charge my "impulse POWER battery (2S, 480mAH) sold by hobbypeople.net" as shown in post number 58 above.
The wires on the balance connector on the battery don't match the colors on the balance connector for the charger.
There are two red wires on the charger connector and two black wires on the battery connector.
If I was to plug the pack right into the charger connector (Polyquest adapter) there would be a red and a black wire (on the battery) connected to the two red wires of the charger. One of the black wires would be connected to the black wire on the charger.
I guess my question is, are all packs made so the balancing connector has a common ground and seperate + leads, or could this pack have a common + lead with seperate ground leads for each cell?
Can I probe the balace lead with a volt meter to determine which lead is which without the pack bursting into flames?
I did I say LiPo is new to me?
Here is a good link with some great information..
http://www.commonsenserc.com/page.ph...education.html
Jeff
www.CommonSenseRC.com
Unless the balance tap configuration has reverse polarity, all you need to do is plug the balance board into the BC-5, then the balance tap from the lipo into the appropriate socket on the balance baord, then the charge cables from the charger output to the battery discharge leads.
Evan
RC Accessory, Inc.
Am I the only one that could not get a Bantam BC5 charger to work in balance mode, after reading the insructions saying you don't need to connect the battery output lead. WELL I FOUND YOU DO, then it will work see photo on connections
Bantam as well as my web site, www.rcaccessory.com denote that all of the BC-x chargers require 2 connections to the charger. The manual should be updated on the next production run.
RC Accessory, Inc.
I'm a newbie at this. I just got a Bantam e-station 701 charger not knowing that I had to get a power supply as well. D'oh! I just got back into this hobby again after several years absent from the rc scene, the last time I left, all the chargers already have their own in-built power supply and they only need power cables lol
Can anyone please shed some light as to what I need to know about getting a power supply for the charger?
Please bear in mind I'm in Australia so I would most probably need to get something different than you guys in America.
I was looking at this:
http://www.rcmart.com/catalog/produc...ducts_id=22627
Would that be a suitable one for the charger?
Thanks guys..
i just bought a bantam 301dx and a bantam pb-5 ballancer. do i need a cable to join the two together for the charging process??
RCAccessory,Inc'
Auth USBantam Importer
http://www.rcaccessory.com/index.asp...ROD&ProdID=459
The all new Bantam e-Station BC8DP sets the standard for AC Powered chargers with features and functionality with an ease of use that is well known for Bantam e-Station lipo balance chargers.
The e-Station BC8DP is a TRUE dual power (AC and DC Power) lipo balance charger. A huge 128 x 64 backlit LCD display that will not just show you your battery statistics but also you can view the charge and discharge graph's right on the chargers display! Included with the Bantam e-Station BC8DP is the EAC300 software graphing kit as well as 1 Temperature probe, EAC110.
<big><big>SPECIFICATIONS:</big></big>
AC/DC Power 11V to 18V Input | 10 Amp Max Charge Rate | Up to 8S Lithium (Li-Po, Li-Ion, Li-Fe (A123) |
180 Watts Charge Power on DC Power 120 Watts on AC Power | 5 Amp Max Discharge Rate per Channel | Up to 22 cells Nicad / Nimh |
25 Watts Discharge Power on AC or DC | Balancer Bleed rate: 200 mah per cell | Up to 28V Pb (SLA/Lead Acid) |
Battery capacity up to 65,000 Mah | Nicad / Nimh Cycle count: up to 10 Cycles | Nicad / Nimh Trickle Charge up to 300 mah |
10 Battery Memories | Delta Peak Sensativity 5mV to 20mV | Nicad / Nimh Formation charging - Timed |
Weight: 1400 grams | Size: 170 x 170 x 75 mm | Warranty: 1 Year |
<big>Lithium battery charging</big>
The Bantam e-Station BC8DP supports the 3 lithium battery types used in RC applications. Lithium Polyer, Lithium Ion, and Lithium Iron Nanophosphate (A123 Systems). Each lithium type has its own low voltage and high voltage parameters and the Bantam e-Station BC8DP has these preprogrammed for you. Just select the lithium type and you are ready to go. The Bantam e-Station BC8DP supports several charging/discharging programs for all lithium battery types including Normal, Balance, Storage, Fast, and Discharge.
<big>Nicad / NIMH battery charging</big>
The Bantam e-Station BC8DP supports both charging, discharging, cycling, and formation charging of Nicad and NIMH batteries, up to 22 cells. The Bantam e-Station BC8DP supports 3 types of Nicad / NIMH charging. Nomal charging, Linear charging, and Reflex charging. Each treat the Nicad / NIMH differently. Batteries with high internal resistance the Bantam e-Station BC8DP has the ability to delat the peak detection from 1 minute up to 15 minutes. The Delta Peak sensativity is also has 3 parameters, Default, Disable, and Delicate. The Delicate setting allows the charger to detect very minor variations in the delta peak voltage which some NIMH batteries may require.
<big>Screen Display While Charging</big>
RC Accessory, IncThe Bantam e-Station BC8DP during the battery charge or discharge program will show you the battery information on the LCD display. On display graphing of the battery charge or discharge curves, individual cell voltages, as well as temperature, capacity, time, and mah input and output are all viewable.
